Tekin RS ESC sensored >
Old 06-25-2009, 08:36 PM
  #4501
beemerfan's Avatar
Trader Rating: 39 (100%+)
Originally Posted by stitchy
I'm running Novak 17.5 with mechanical timing turned all the way down (per rules) and 30 boost. Gearing is at 3.72 FDR.
I've never opened my Novak 17.5 can. It is one with a yellow timing ring. Can anyone tell me what the timing is set at from the factory?
beemerfan is offline
Old 06-25-2009, 08:38 PM
  #4502
Krio's Avatar
Trader Rating: 159 (99%+)
Novak claims the latest motors have been coming with 25 degrees of timing. The fact that they are not marked on the can makes it incredibly hard to accurately set timing and boost.
Krio is offline
Old 06-25-2009, 08:45 PM
  #4503
beemerfan's Avatar
So if I understand correctly that the total timing, mechanical + boost, should be around 30, I should only be setting my boost to 5, correct? But what fun would that be?
Old 06-25-2009, 10:25 PM
  #4504
ok guys i have heard that you can not use the rs with novak motors is this correct? and if so why and why not
JdogL is offline
Old 06-25-2009, 10:29 PM
  #4505
reenmachine's Avatar
Trader Rating: 26 (100%+)
No, that is not true in the least. Read the previous couple of posts about it being difficult to determine the mechanical timing on a Novak motor, but there's no incompatibility with Tekin ESCs.
reenmachine is offline
Old 06-25-2009, 11:25 PM
  #4506
Trader Rating: 13 (100%+)
Yeah, not true. I'm using a Novak motor right now
stitchy is offline
Old 06-25-2009, 11:38 PM
  #4507
what about tekin motors with novak gtbs
JdogL is offline
Old 06-26-2009, 12:03 AM
  #4508
Tpg racer's Avatar
I'm asking on behalf of a friend of mine....
His question was, should he maxed out the timing capability on the esc itself or does he needs to advanced the timing on the motor too to get the amount of power he wants?
What more can he do to get the extra "oommpphh" from his stock 11.5 motor ?
I have not tried advancing the timing on the motor itself coz I'm not using Tekin RS esc but just asking on behalf of a friend...
Thnx in advance
Tpg racer is offline
Old 06-26-2009, 04:49 AM
  #4509
C5Vette's Avatar
Originally Posted by Kingsbury
For the guys waiting on V199. I have been running it for almost 2 weeks now. I'm sure Randy will give a good starting setup once pre-release testing is done but from what I have been running lately here is what I have been running on an medium sized asphalt track.(17.5 and 13.5)
Tekin 17.5
4.3 FDR, 12 motor timing, 13 Boost, MAX turbo.
Tekin 13.5
5.3 FDR, 10 motor timing, 15 Boost, MAX turbo.
It's well worth the wait guys, say bye bye to the SPX on the straight!
What type of car are those setting for?
C5Vette is offline
Old 06-26-2009, 04:53 AM
  #4510
Trader Rating: 16 (94%+)
Looks like Rubber Tire TC.
kn7671 is offline
Old 06-26-2009, 06:05 AM
  #4511
Same story. The GTB and RS will both run any modern sensored brushless motor.
Old 06-26-2009, 06:50 AM
  #4512
beemerfan's Avatar
I think I read in Novak's documentation somewhere that you are not supposed to use their motors with any speed control that is capable of adjustable timing. I believe this is pretty much a warranty disclaimer of some sort. The motor works fine. I'm running my RS Pro with a Novak 17.5 spec motor and so far haven't had any issues.
Old 06-26-2009, 07:19 AM
  #4513
Trader Rating: 50 (100%+)
Yes rubber tire TC, thanks.
TC5
Kingsbury is offline
Old 06-26-2009, 08:00 AM
  #4514
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Anyone know if the 198 version works with 1 cell lipo without a booster or rx pack? I'm trying to avoid buying stuff I don't need now or won't need in the near future.
ToysRUsKid is offline
  #4515
199 is a pretty big step. It's going to take a little time to figure things out more. It's a huge change on the straights (just keeps pulling).
Just wish it would quit raining at Nats.
Fred_B is offline
