Tekin RS ESC sensored
#2117
#2118
#2119
#2120
In order to use the sensored only mode you'll need to get the Hotwire interface. It lets you select sensored only mode and you'll be able to update the speedo when there are updates.
I like sensored only in the slower stock classes and 12th. I think the dual mode works best in mod (especially on dirt).
I have the Hotwire next time I will try it.
I had another problem. One of my friend told me, if you adjust the timing via speedo when you use a sensord type motor is ineffective. Is it true?
He said that the speedo timing only effect the sensorless motors...
#2122
Unless the motor has fixed timing (speedpassion) you can get more timing by running sensored only and turning up the motor timing.
The next version of software does allow an additional timing "boost" for sensored only mode.
Gearing can be a little tricky with higher timing so be careful.
#2123
Most of the team guys are running around 35 degrees of timing for the TC classes using 17.5's and 13.5's.
The lower turn the motor the less timing you will need. Check the temps as you add timing. You should be dropping your gearing if you add ANY boost.
#2124
anyone???
I just got a 13.5 Redline and was wondering two things. One, how you read the timing. It appears that it comes set @ 14 degrees by the mark on the cap but Im not for sure. Two, I will be running this motor in a TC with a GTB, track size is 90 X 50. How much timing would you recommend starting with?
#2125
Does anyone know what the timing is on the lrp x11 "stock spec" motors?
I ran the 9.5 motor with boost on 16, but the car really lacked overall speed at yesterday's race. (12th scale) I might not be able to set the boost at the track, so knowing the timing on the motor could be usefull.
#2126
This weekend race was the first time that I ever tried sensored type motor and my new Tekin RS PRO.
In the first heat my car was so slow. Slower than others. I used a Novak 13,5 turn motor. In the first heat the timing setting was the default.
In the second heat I increased the timing to 40, but nothing changed.
In the third heat I increased it to 80 and tried a new FGR (5,2). The motor was still cold the car was a bit faster.
I noticed that the timing has minimal effect to the speed or am I wrong?
Pls. help me how can I increase the speed, what are the optimal settings for a 13,5 turn motor? Or what was my mistake? My problem is that I don't feel the timing effect... The motor was cold however the timing was 80 and the FGR was 5,2.
#2127
gfarb: They come set at 12 degrees in the box. If you look at the endbell side of the motor(non pinion side) simply rotate the endbell after loosening the 3 screws and turn it counter clock wise for more timing (24 max) or clockwise for less.
Last edited by Randy_Pike; 01-19-2009 at 03:11 PM. Reason: Thanks for that Chris! LOL
#2128
I didn't get a chance to try out the new software this past weekend at our race. I'll be bringing it with me to the Snowbirds though...will there be any Tekin people there should I decide to try and use this as a tuning aid?
#2129
We have almost a dozen team guys there at the birds in almost every class. Anyone one of them will be more than happy to help out.
