Tekin RS ESC sensored
#3616
I'd have to agree this support is second to none. I like it so much I want to buy an rx8 esc, I just don't have a car to put it in.
and yes the interface needs work, but it works. So I don't care.
--pakk
--pakk
#3617
Please make it simpler and easier to read.
#3618
Ok guys we get it. We're looking into "alternatives." We think that having a different interface for each unit sets them apart. I personally like knowing what esc I'm plugged into by seeing the graphic.
I do understand that some "uses" may require a different size to fit the screen.
As always: You talk, we listen.
#3621
#3622
#3623
just a question on capacitors. The tekin comes standard witrh a 16v330. Is it possible to use a 10volt capacitor? I presume it can handle the the 7.4volts from the lipo i use? or is the 16volt really needed? I drive modified motors so i want to use two 10v1200 xtremely low Impedance caps.
#3624
#3625
while we are bashing the hotwire, I'd like to add something. The ability to save profiles would be nice. That way we could save settings for different motors, tracks, cars, and what ever else changes the esc settings.
--pakk
--pakk
#3626
I understand where everyone is coming from. The best part is that everything said was constructive, thank you for that!
Truly shoes that our customers "get it" and want to see the same improvement we do here at Tekin.
I will pass on all the good info.
#3627
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
We're all complaining about the HotWire being hard to read cuz we're all old and can't see!
Just kidding honestly. Now I gotta go clean my glasses.
#3628
#3629
Hey, I just purchased a new RS speed control and need to reverse my throttle, which is fine but when I power it off and power it back up I have to reverse the thottle back to standard then back to reverse. Is this normal? Also when on it has a high pitch whine to it? I'm using a DX3s for a radio with a SR 300 reciever. Any ideas or is this just normal
Kelly
Kelly
#3630
If enough people request it, I'm sure Tekin would build the car to place that RX8 into The feed back is awesome and the updates that you don't have to pay for are un heard of. They are doing something right
