Tekin RS ESC sensored
I mainly run 1/12th but I can give you some pointers.
LRPs don't like as much timing as most other motors (they have a lot of timing in them from the factory) so for boosted, use the -10 insert.
Start with about 40 boost, maybe 8 turbo.
20k end rpm, maybe around 4 or 5k start.
start rpm: 8000-9000
end rpm: 20000 to 22000
boost: 40 (42)
turbo: 15 (18)
delay: 0
ramp: 2
FDR i think should be somewhere around 5.5-6, but gear it to suit your track as the layout is an unknown to me.. you will prob be getting motor temps somewhere around 70 degrees when its geared properly.
-Mark
i havent tried it as i have no need, but one of the guys at the club has..
you need to install the older software (in this case 203) then install the newer version (212) into a different folder on your computer..
for example..
v203 installed to "c:\program files\tekin203"
v212 installed to "c:\program files\tekin212"
then you just need make sure you have 2 shortcuts to the hotwire executeable which point to the 2 different folders.. shortcut 1 becomes v203 and shortcut 2 becomes v212..
no reason this shouldnt work for you
-Mark
for example..
-Mark
I'll give that a try but I'm not the good on the computer.
Thank you
Thank you
Last time, I try my car in a track with 5-60m straight. Running M.M.H 9.5T high rpm type motor with V208.
Car have very fast speed. After 10 minutes run, only 67C degree. (air 15C degree)
I use M.M.H 5600mah 55c in my tcx and fdr is 6.3
boost max
start rpm 2xxx
end rpm 10000
turbo delay 0.20
turbo max
turbo ramp 3.0
throttle profile 3
current limiter 80
drag brake 0
neutral width 3
boost max
start rpm 2xxx
end rpm 10000
turbo delay 0.20
turbo max
turbo ramp 3.0
throttle profile 3
current limiter 80
drag brake 0
neutral width 3
I am moving from 1s 10.5 boosted to Mod 5.5 and was going to run the blinking led profile as I dont want boost. Does anyone know what a good throttle profile would be to start on ?
Also the RS says sutable for 5 turn brushless max so I think it will be ok for 5.5 with 1s ?
It's noticeably smoother
And TP3.
I just want the speedo to control the motor and not add anything if that makes sense. But if the feel is better i will try it.
Thanks for the help guys
Guys First time to run 5.5 no boost, I feel like the motor have a lot of torque, especially coming out on a turn, can anyone help me with my Tekin rs, I really want it race with no boost but if someone can give a set up for boosted I will give it try, track condition low traction and about 160x100
Thanks in advance
Thanks in advance
You guys deserve it
Lots of hard work no doubt
definitely worth it,now hurry up and get the motors done i want one,well actually a few
Any body have any Idea why my RS now acts like it has No Boost?I have reloaded the soft ware and recalibrated the transmitter.The ESC did not get hot,the most lights that showed on the temp was three.
This is the fifth that I have had fail but the first one where the ESC acted like has no boost.
im playing 17.5t with timing/boost off...
what software is suitable with 0 timing...? 212 or 203
thank guys..
thank guys..
