Tekin RS ESC sensored
Hi, guys, doesn't anyone use LRP X12 17.5 motors with Tekin's.
What's the smallest recommended wire gauge for use with 25.5 no-timing up through 17.5 boosted?
Looking to trim some weight. I think I've been running 16 gauge (or maybe it's 14, can't remember) with no problems. I'm wondering if I could drop to 18 or even 20 gauge.
-Mike
-Mike
i use 16g in my 12th boosted 13.5
LRPs don't like as much timing as most other motors (they have a lot of timing in them from the factory) so for boosted, use the -10 insert.
Start with about 40 boost, maybe 8 turbo.
20k end rpm, maybe around 4 or 5k start.
Just want to remind people I have HotWire Software help guides up on the site:
http://www.teamtekin.com/hotwire_rs.html
And also have a page to show all the LED sequences on the RS interface:
http://www.teamtekin.com/rs_troubleshoot.html
the trouble codes are awesome nice work TY
Looking for help in finding a way to save more than one software on the same computer.
you can have two saved its the custom 1,custom 2 in the timing profiles
I mainly run 1/12th but I can give you some pointers.
you need to install the older software (in this case 203) then install the newer version (212) into a different folder on your computer..
for example..
v203 installed to "c:\program files\tekin203"
v212 installed to "c:\program files\tekin212"
then you just need make sure you have 2 shortcuts to the hotwire executeable which point to the 2 different folders.. shortcut 1 becomes v203 and shortcut 2 becomes v212..
no reason this shouldnt work for you
-Mark
