GM Brushless
#1382
yes 1.6.3 seems the newest version
#1383
How do the following work together..
Fixed Timing and Max.Timing
So Fixted Timing is set to 21
and Max Timing is set to 26..
How does they effect each other? the manual is not very clear in this area.
#1384
gm 120 v1 firmware 11.1
Hi martin, you tell me if this is fine, as programmed in mode 3 beeps and when I connect the PC and download data from the program I get speedo mode 2
I have a speedo GM 120 v1 and when I connect to the program as tool v 1.4.0.xx genius, I get firmware version 1.1, and when I read the data I get my speedo (37 - firmware 11) is correct that speedo would have to do is my version 1 is the beginning of 2009
#1385
Hi Martin
I've recently got a GM 90 2010. I was running at west London today geared at 4.7 as you recommended and the speedo setup as you've described (13.5 novak ballistic std timing) the car was very very quick for around 4 mins and then got very soft. It was such a difference I wondered if I cooked the motor, so I checked the temp and was surprised to discover that it was only 55 degrees?
I spent the day going up and down gearing and taking some of the timing off the motor etc but it still happened?
Do you have any ideas as I'm confused as to what could cause this.
It was a shame as otherwise it was fantastic! Very smooth and very fast.
Thanks in advance
Ade
Thanks in advance
Ade
#1386
I had a little trouble with the softstart setting. When at 50 in the software the car would pull up to the line and then not start when my start beep was called! I changed this to 60 (67ms) and it has not repeated the fault.
#1387
Dude, with GM 120 and others Version 1 (like 90/120 and "old can" like 50/95/100..) use 1.3.6. If software is < 6.0 use 1.1.5.
Then you download RIGHT data and don't mess us with 11.1 for old one ;P
good luck!
m.
#1388
Sensorless motors.... where is the option? in software ver 1.6.3 for GM120 II
#1389
Hi Martin
Thanks in advance
Ade
Thanks in advance
Ade
you will see a motor temperature value in the telemetry section. I reckon it will show about 95°C. As you say it had 55 on the outside you could change the "maximum motor temperature" in the second tab to 130, and do a run again. then you should have about 85° on the can. which is about right.
for Gm motors, use 110°C, for Graupner (silver 13.5/17.5) use 127° and for LRP X12 (if you are forced to run it as it is not really fast *G*) 115°C
Well i had my run at West London today and 4.7 was a great starting point! (cheers Martin!)
there is no option, just use mode 2 or 3 or whatever and unplug the sensor lead, that's it
#1391
Martin wich motor works better and is fastest for TC Stock(9.5), with new genius2 120 ?
Thank you
Thank you
#1392
#1394
Hi Martin
Thanks for the help I'll give that a go when I next run the car. Do I guess then that the speedo is pulling back the power as it thinking the motor is getting too hot?
I'd also like to say that the thing was seriously fast, when I was tracking around on my own it was so smooth that you could almost mistake it for not being that fast.
However in my heat there were some very good drivers, one of whom had a Tekin with v203. Everyone else kept saying how he destroyed them down the straight, when he came around to put a lap on me (I make too many mistakes ) he was a couple of metres behind me onto the straight and was still a couple of metres behind me at the end! If anything I'd have said a little further back but I was going too fast to really be 100% sure lol
So I'm very very impressed indeed with the speedo!
Ade
Ade
