Kyosho VoneR Thread
Originally posted by Rob Hochberg
I have just been informed by the seller that I need the body post extensions. Anyone know what the P/N is? I am going to "borrow" the posts off my Xray in the meantime.
Re: V 1 RR EVO WITH XS3 RX'er
Originally posted by gkp5569
DOES ANY ONE HAVE A SUGGESTION ON HOW TO MOUNT THE XS3 SYNTHESISED RX'er RS300 IT IS TO BIG TO PUT IN THE MOUNT IN THE MANUAL. AND I CANT REALLY FIND A GOOD SPOT THAT IS NOT NEAR THE FUEL TANK.
HELP IS APPRECIATED
GARY
HELP IS APPRECIATED
GARY
AMG you got PM..
Ok guys, I did the M1RR Conversion. Although I haven't put my car on a setup board it still looks like there's not enough negative camber. I know it's better than the stock rear hub. I even shortened the ball end. Maybe you guys can take a look and see if see anything I did wrong
pic2
pic3
last one
Servo saver
Hi guys, can anybody pls tell me the effects on the use of
servo-saver no. 10, 11, 12.
Thanks alot...
Thanks alot...
Re: Servo saver
Thanks alot...
Thanks alot...
Originally posted by Nitropimp
last one
last one
AMGracer- So do I have to use different turnbuckles?? How do I shorten them down???
AMG- thanks....
Originally posted by AMGRacer
If you use the standard Kyosho Turnbuckles the adjutment flats are much narrower. This allows you to wind them in a long way which is required when using the MTX3 rear hubs.
Originally posted by mrckymrk
Hey AMG, I noticed that the rear was quite loose when using the mugen rear hubs. How much camber do you recommed and is it suppose to be this way? I did feel that it takes a little getting use to but I think it is faster around corners.
