Tamiya TA05MS
#511
#514
just want to ask if your balldiff pulley has some slop/play left to right? because my stock balldiff has some play left and right and for me the tightness of the diff is enough but it has some play left and right.
but if i will compress both diff joints and rotate them its very smooth.
i think the differential plates are not fully attached or close to the balls thats why its not smooth. but if i will compress it and rotate them its smooth..
#515
not yet.. i'll let you know if ever.
About the 16 balls, let me know ASAP you make one ha...
#516
What do you mean by play left and right??? When you move it, it goes to the left a little bit and vice versa??? If so, only my front one way is like that but my rear isn't... But the whole diff is moving left and right but the diff (pulley) itself is not... Gets??? Tighten the diffs as if you cannot turn it anymore but hand (fingers in this case) and afterwards, tighten it using the an allen wrench and try to tighten it maybe 5 degrees more or atleast less than 10 degrees... This is what I do so that it wont get loose after runs...
#518
no, it doesn't move. why?
#520
it does move but only a very very little action.. try to disassemble and put it back again.. mine's also moving before then i dissassembled it and put it back and its fine now..
#522
any people who complains about the stock ta05ms balldiff??
#523
There usually is some play between the bearings in the diff holder in the bulkhead and the diff/one-way/spool. Use shims to take some of the play away. But if you make it too tight, you'll lose drivetrain efficiency.
nikkiesteban, my ball diff works fine. Is your's malfunctioning?
#525
