JConcepts Thread
#1186
Here are some results from our Fri. night race for the main. Just to give you guys ideas about what i am up against.
Here are some lap times. and YES 7 Min mains!
Pos Car Laps time name id Car:
1 1 32 7:12.86 Roger S 29 XX4
2 5 30 7:00.07 Dave C 5 x-5 / XX4
3 3 30 7:12.69 Andy W 3 ?
4 9 29 7:13.14 Randy H 4 ?
5 8 28 7:01.60 Dwaine P 1 XX4
MOmo
MOmo
#1187
This was my experience the first time but once you have done it a few times (and use a ball-end 2.5mm driver) it will be easier (not that I have to change motors often).
Once you get used the the dynamics of the car, and downside the jumps this will not be a problem.
#1189
Yes, Get a long ball-end wrench. I can get to it from behind the shock. After a few times, it isn't hard at all.
#1190
I got to try some Double Dees in Green Compound on my B44 today. We usually run M3 Holeshots on this particular track so I knew they should be close.
After running about 15 minutes on them all I can say is wow. They feel better than my Holeshots but I am sure it is due to the fact the Carcus on the Doudle Dees is a little more rounded. It made the car corner much more predicable on the slippery parts of the track. Also the stock inserts are awesome...like a Trinity Bomb one insert. My car also felt like it had better forward bite probably due to the rubber compound and tread pattern.
Any way just wanted to say great job on the tires guys.
#1192
Yellow compound tires are in the works also (on of those projects), and should be available Q1 2008 (estimate). Yellow will be the harder of the two 1/8th compounds.
Ahh ok, cool. Be patient, launching a tire line is surprisingly involved, haha.
#1194
Rod Rippie (I hope I spelled that correctly) maybe at the Midwest Champs. He's from southern IL and still runs the BJ4. I can't say for sure if he's going to be there but I know he's fast and will likely be in the main if he makes the trip.
#1196
Jason-YGPM
#1198
Ok I am new to 1/10th electric.
I'm the Australian Distributor for JConcepts so I thought I would drive a BJ4WE but I dont know what to put in it. What would every one say is the best motor combo to pick, I guys it would be brushless but what one and then theres the battery issue but tires are no problem I hear there are some great tires out now .
#1199
I see guys who wher racing BJ4s are now driving B44s,Why is that?I have a BJ4we,and they are very much the same ant they?
