Novak Super Sport Brushless Motor System
#317
Trader Rating: 22 (100%+)
i have a hacker 6turn
my frieind has the novak
my hacker is MUCH faster
even on the lowest setting
Hacker motor with Shulze speedy, the best combo
(as long as it doesnt thermal overload it should be, will know this thursday)
#319
you unsolder it and cut it...... then sodler it back...
is there anything bad about shortening the wires
#322
You shouldn't really try to shorten the wires. The assembly inside the motor is not easy to get to. Cutting the wires and splicing will usually lead to problems. The wire is not very easy to solder or work with so most times the average joe can't get them back together right. You should just coil and zip tie them in a nice little bundle.
Charlie
Charlie
#323
Thanks charlie...i've tried and failed to get inside the motor's circuitry anyway.
hope u can answer these questions b4 u get offline.
1.I was on stock profile(No.6) with 7.14 ratio.I top out halfway thru the straights...does it mean i can use taller ratios?
2.Is around 60-70 C's or about 140F-160F acceptable temperatures for the ESC?
#324
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
help for a rookie
Hi Guys,
I just purchased this baybe and forgive me for asking but whats the difference between profiles 1 and 3 and 2 and 4? What is Min Brake??
#325
any cogging or brake fade problem with it?
i have seen other RCers install a 6V receiver batt pack to overcome the cogging problem...
#326
Re: help for a rookie
Originally posted by Kennedy
Hi Guys,
Hi Guys,
#327
New BL motor
Anyone know when the new novak BL motor will come out? Would it be rated around 6t?
#328
people say its should be as fast as the hacker 8t but more torque then it
#330
the 414MII is also very tight
the brushless may look REALLY big... but really it isnt... its the same size
