Alex Racing Barracuda R2 & R3 >
Like Tree5Likes
Old 04-04-2004, 10:28 PM
  #10411
Entropy's Avatar
Default Re: Re: Re: Re: Fish tank sale
Originally posted by AWOLsoldier
good choices... but what does living close to tamiya have to do with anything?
Perhaps the Tamiya Men in Black come round regularly to "cleanse" the neighbourhood of infidels...
Entropy is offline
Old 04-04-2004, 11:13 PM
  #10412
Trader Rating: 32 (100%+)
Its because the track is right there for him.They only allow Tamiyas on thier track on saturdays.I would own one if I lived that close but since I dont I am ok without it.R3......
racenut123 is offline
Old 04-05-2004, 06:53 AM
  #10413
JusBox's Avatar
Oh I see... I'd probably have a tamiya in that case too.
JusBox is offline
Old 04-05-2004, 07:51 AM
  #10414
Trader Rating: 28 (100%+)
The R2/R3 continue to dominate outdoor tracks & races in this area.
That is the one item that has me worried about picking up a 415, but seriously if anyone has a good home for a great car shoot me a PM.
madjack is offline
Old 04-05-2004, 07:28 PM
  #10415
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
hey madjack I;ve been hearing about 415,tamiya have not made any front diff for 415 yet and rear diff is different than the front way diff pulley..You might waiting alittle longer before get the 415 just my two .02 cent
OVA is offline
Old 04-05-2004, 08:11 PM
  #10416
KJ
Can anyone share what does the "kick up" does for the car?
Kick up = black color shims that place under the balls holding the arm. 0.8, 1.2 mm ...etc.
What if we have all 4 balls being raised? My thot is it would increase traction. Am I right?
KJ is offline
Old 04-05-2004, 08:13 PM
  #10417
raving-monkey's Avatar
correct me if i am wrong but i think kick up does the same thing as caster.
so more kickup will give more steering (i think)
raving-monkey is offline
Old 04-05-2004, 08:46 PM
  #10418
GTO2's Avatar
i thought kickup is the angle between the lateral arm and chassis.
caster is the angle between upright and chassis.
changing kickup angle will affect its caster but not applicable vice versa.
GTO2 is offline
Old 04-05-2004, 08:50 PM
  #10419
GTO2's Avatar
i usually apply rear kickup to fine tune traction.
If all balls being raised, almost the same as lowering the ride height where the balls at. The traction would be the same as they weren't raised, if the ride height is maintained the same.
In fact at that, the arm is in higher position, making the CG slightly higher.
GTO2 is offline
Old 04-05-2004, 08:56 PM
  #10420
GTO2's Avatar
After about 20hrs runtime, the plastic shaft holder start giving way. The front holder is a must, and I changed it already, now it's time for the rear, it means alot for alignment and efficiency's sake. Changed back my alum shaft to carbon, found it a bit offcentered compared to the original carbon...
GTO2 is offline
Old 04-05-2004, 08:58 PM
  #10421
JusBox's Avatar
The plastic holders suck. Mine didn't even sit flat, the top deck was bowed. The aluminum holders fixed that problem.
JusBox is offline
Old 04-05-2004, 09:26 PM
  #10422
ive deicded to go for the pro4 or cuda r3.
but ime stuck triyng to find anywhere in the UK that sells cuda parts.
can anyone fill me in to where i can get parts?
as i don't want a car that will take me 2-3 weeks to get parts if i need them
you know what i mean
Old 04-05-2004, 09:27 PM
  #10423
GTO2's Avatar
hehe, I place 0.5mm spacer sandwiched between the plastick shaft holder and the upper deck to make it straight.
My uprights are still all plasticks...time will come for me to change them.
GTO2 is offline
Old 04-06-2004, 05:30 AM
  #10424
dhiracing.com is offline
Old 04-06-2004, 05:38 AM
  #10425
Hi raving-monkey, we just sent you an email
