Alex Racing Barracuda R2 & R3 >
Like Tree5Likes
Old 03-18-2004, 10:43 PM
  #10261
SpeedTech's Avatar
AWOLSoldier,
Please send me an email at: [email protected]
I think I got the Xenon bits to put together a drive system for you.
Steve Wang
SpeedTech is offline
Old 03-18-2004, 10:47 PM
  #10262
JusBox's Avatar
Originally posted by SpeedTech
AWOLSoldier,
Steve Wang
Thanks steve i'll do that. Any comments on my question above? I think it's just how the car is but i just want to make sure.
JusBox is offline
Old 03-18-2004, 11:00 PM
  #10263
SpeedTech's Avatar
AWOLSoldier,
About droop...everyone's got their own theory on it, and everyone uses a different measurement number, which is sometimes what makes it confusing
I use the Yokom YT-HDG Ride height and droop gauge and basically for droop it measures a certain point on the suspension (for me I use the bottom of the C-hub and bottom of the rear hub) and its relationship with the chassis. For example, I'm running 7mm droop in the front and about 5mm in the rear. What that translate to is that particular point on the front suspension is 7mm above the chassis (bottom part of the chassis) and the rear suspension point is 5mm about the rear (bottom part) of the chassis.
Hope that helps.
Steve Wang
Old 03-18-2004, 11:08 PM
  #10264
JusBox's Avatar
AWOLSoldier,
Hope that helps.
Steve Wang
I think i'm not being clear enough... i'm not specificly asking about droop. What i'm trying to say is that the front suspension arms do not travel all the way down, the c-hubs limit this. This is with no droop screws installed and the shocks removed. Just wondering if this is how the cuda is supposed to be. It does this with the stock c-hubs as well (i'm running the xenon aluminum chubs at the moment).
JusBox is offline
Old 03-19-2004, 12:47 AM
  #10265
AWOLsoldier is right ...
With the Xenon Front C Hubs (especially), the front suspension arms cannot travel all the way down to touch the chassis, even without installing the shocks. Is this normal or we need to make some modifications to the suspension arms?
Regards,
Mark
dhiracing.com is offline
Old 03-19-2004, 08:53 AM
  #10266
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
I have the same problem...I just to make sure that my ride height is 5mm and no higher
OVA is offline
Old 03-19-2004, 03:22 PM
  #10267
Is it just me or does it seem that the R2 is being discontinued. No body has any anymore. RC Mushroom sold their last ones and are not geting anymore, and Steve doesn't have them at Speedtech. I would get a R3 if I already hadn't spent so much on parts for the car and I don't really care for the TC3 steering rack. Any of you guys on the other side of the world have any info on this.
NismoSkyline17 is offline
Old 03-19-2004, 03:24 PM
  #10268
rc-zombies's Avatar
yes..pretty much the R2 was discontinued when the R3 was released...
rc-zombies is offline
Old 03-20-2004, 01:23 AM
  #10269
Hi NismoSkyline17,
Are you interested in a brand new R2 or only spare parts for the same car?
Old 03-21-2004, 09:28 AM
  #10270
Hi guys,
Did anyone manage to make a locked front diff for the Barracuda yet?
Regards,
Mark
Old 03-21-2004, 10:22 AM
  #10271
Merciless's Avatar
Default Xenon hubs
Can someone tell me if the Xenon R2 alloy hubs are suitable for the R3
I assume the fronts are exactly the same, but i'm sure i've read that the new R3 rear hubs are a lower roll-center and also that the Xenon are a different roll center to the std. R2 ones but are the XENON alloy hubs and the R3 std. rear hubs are same roll center ???
HELP plz
Merciless is offline
Old 03-21-2004, 10:24 AM
  #10272
JusBox's Avatar
Regards,
Mark
bumping this post as we've yet to see an explination.
JusBox is offline
Old 03-21-2004, 10:38 AM
  #10273
SpeedTech's Avatar
It's normal, I have the same thing on my car. The droop setting you end up with the Xenon C-hub is ideal for most track condition. If for whatever reason you need to bring the arms back down and run less droop, switch back to the plastic hubs.
AWOLSoldier,
I got your email, I'll put together a price for you Monday.
Steve Wang
Old 03-21-2004, 10:47 AM
  #10274
JusBox's Avatar
AWOLSoldier,
Steve Wang
Ah ok Steve. So what you're saying is that it has built in droop? Sounds good, we just wanted to make sure.
No rush on the price for the xenon stuff, i know you're a busy guy.
JusBox is offline
Old 03-21-2004, 10:48 AM
  #10275
Regional Moderator
ImGoinRCn's Avatar
I went back to the plastic rear hubs, teh ones that reduce rear tow and running the ront Xenon hubs and didn't break anything this week. For some reason, the regular setup, teh car wanted to skate around the turns. It might have been the humidity b/c of a rain storm that went on during the races...but what do I know...
Merciless' sig sums it up for me...if I wouldn't have piped it twice, it would have been another Cuda victory...prolly costed me the points. Stil, had fun though...first time in a while.
ImGoinRCn is offline
