Xray NT1
#4742
Thanks for the answers...
So with a car that much maintained, how close are your values when you just lift the car and put it on the scales, or you put it on the scales and compress the suspension couple of times to let it settle?
Of course most of the problems will go away with a properly working car, but for example when I just compress the rear end, there will be more weight on the rear scales. That is what I can't figure out how to do it same again and again.
#4743
Capricorn Composite Diff Gears
Any info about Capricorn composite diff gears durability ?
Shaving 10 grams per diff might be an interesting upgrade...
#4744
Well, it is used as a stock part in Lab-c01, so I dont think it will be an issue.
There is also a racer in France telling that he ran the car for 4liters(about 4 hours) and no problems on the car.
#4745
I have them but haven't used them so far.
The original diff gears are a bit over-engineered since they don't wear at all. Never have to inspect them.
The composite ones, I would inspect regularly. And maube change them half around the season.
But like Musti says, they are used in the Capricorn car as well, and the stuff Capricorn makes is all of the highest quality.
#4746
I also have the differential gears (and alluminium diff pins) but I've not tried them yet. sorry..
Anybody has tried the capricorn's belts on the NT1??
Capricorn's belts seems to be softer than the xray's ones...
#4748
If the capricorn ones are compatible with the NT1, those could be a valid alternative to the stock xray belts. Probably not so durable but not bad as the original options (that xray do not produce anymore).
#4749
I wanted to say that maybe capricorn's belts could be better than xray. I used the word "soft" in a positive way. A softer belt can give a smoother drivetrain...
#4753
how about Shepherd belt ? they are all same size
#4755
is anybody running kopropo mid/low profile servos on the nt1 if so which ones you guys using and how do you like them thanks
