Xray NT1
#2221
www.ybslowinc.com
On the left side, click on purchase products then just find what you want. There are two different weights available.
#2222
YBSLOW stuff
That's nice lookin' stuff Brad. When I get my kit I know who to call!!
#2223
Yes, it is a brass battery tray. You can purchase it at:
www.ybslowinc.com
On the right side, click on purchase products then just find what you want. There are two different weights available.
www.ybslowinc.com
Mark
#2226
#2227
XRay takes 1, 2, 3 & 4 in the SS Kyosho Nitrofest.
1 Mark Harrison 127 00:30:07.014 Fast Lap:00:12.563
2 James Burrows 124 00:30:02.895 Fast Lap:00:12.856
3 Ralph Monteleone 122 00:30:09.952 Fast Lap:00:12.862
4 Art Jenson 112 00:30:11.677 Fast Lap:00:12.883
Mark Harrison had his car dialed and was the car to beat all weekend. Running 42 shore tires was perfect for the traction. Seen many traction roll on the super smooth surface.
#2228
Try running 50 shore tyres in the rear, then run 30 shore tyres in the front to compensate for the hard rears. Forget 40k oils inthe diffs, what you need is a spool front and rear. Also, light purple springs are no good, hot pink is more your colour. Change the gearbox as well, get one of those trick gearboxes with reverse gear, then you will be able to drive in reverse, you will probably finish more races as you won't be snapping the front suspension arms as often. Don't worry if you can't go quite as fast in reverse, because you will still give Grub a flogging.
#2230
Since when NT1 got reverse gear option ?
Are u serious about using spool front and rear ? and 50 shore rear and 30 shore at front ?
You smoke crack or what ? j/k
#2232
#2233
Mark
#2234
A few of guys here have tried it and most have gone back to the stock mount. Regionally our grip levels range from super low to med, I thinks its more of a situation where there just aren't any tracks in the area where chassis stiffening yields a handling benefit. Other who race frequently in high grip conditions may see gains.
Mark
Mark
#2235
rear tyre grip
gidday
can anyone advice me how to get traction to the rear as after 20 minutes i have gone from 62.5 mm 40 shore foam rear tyres to 100 shore hard plastic and other guys still have plenty of tyre left, i have been told than my cars is consantly spinning out of the corners,, it did seem slow out of the corners but i throught it was my clutch running 100k frount diff oil 60 rear with pink springs 33lb please help grub
