Xray NT1
#721
Originally Posted by fastharry
thats even got me scratching my head..
#722
Originally Posted by rmdhawaii
romuald31 ~ This is an interesting addition to your car....
#723
Online Kit Inventory Update (estimated):
Ashford Hobby has 4 @ $429.99
Stormer Hobbies still shows zero inventory (not even a price)
Nexus Racing has 4 - and he raised his price to $429.99! (up $30)
RC Market has 2 @ $398.00
The Border - In stock, but can't tell how many @ $512.88 USD
If so, mine will come soon then!
#724
I was working on an "essential spares list" today and came up with the list below. Quantity is on the far right. All the parts are not online yet, but I did manage to rack up about $259.80* using one online store's prices. I would estimate that the total comes out to roughly $290-300*.
Not included are other gears, diff oil, shock oil and extra screws except as listed below. That would be extra.
If you have any suggestions on what should be added or removed (including quantity) please do and I will update this particular post. Thanks!
Front
332110 - Composite Suspension Arm Front Lower / 2
332130 - Composite Suspension Arm Front Upper / 2
332210 - Composite Steering Block Right / 1
332220 - Composite Steering Block Left / 1
337210 - Front Lower Inner Pivot Pin (2) / 1
337220 - Front Upper Pivot Pin (2) / 1
Rear
333080 - Graphite Shock Tower Rear 3mm / 1
333110 - Composite Suspension Arm Rear / 2
333310 - Composite Upright Rear / 2
333130 - Composite Rear Upper Camber Link Ball Joint 5.8 mm (4) / 1
337310 - Rear Lower Inner Pivot Pin (2) / 1
303122 - Alu Shim 3x6x1.0mm (10) / 1
303123 - Alu Shim 3x6x2.0mm (10) / 1
Belts
335430 - PUR Reinforced Drive Belt Front 3 x 186 mm / 1
335441 - PUR Reinforced Drive Belt Side 3 X 390 mm / 1
335450 - PUR Reinforced Drive Belt Rear 3 X 177 mm / 1
Clutch
338574 - Clutch Shoe White / 1
338584 - Washer S 5X7X0.2 (10) / 1
338585 - Washer S 5X7X0.3 (10) / 1
338586 - Washer S 5X7X0.5 (10) / 1
930150 - Carbide Ball-bearing Axial F5-10 5x10x4 with Groove / 2
359050 - Clutch Bell Ball-bearing MR105ZZZ 5x10x4 (2) / 1
940508 - High-Speed ball-bearing 5x8x2.5 Rubber Sealed (2) / 1
Diff Parts
335060 - Composite Rear Diff Case & Cover / 1
903258 - Hex Screw SFH M2.5x8 (10) / 1
903206 - Hex Screw SFH M2.5x6 (10) / 1
971240 - Silicone O-Ring 24x-0.7 (10) / 1 [ Diff seal ]
Pinion Gears
338521 - XCA ALU 7075 T6 Hard Coated Pinion Gear 21T (2nd) / 1
338516 - XCA ALU 7075 T6 Hard Coated Pinion Gear 16T (1st) / 1
Spur Gears
335559 - Composite 2-Speed Gear 59T (1st) / 2
335555 - Composite 2-Speed Gear 54T (2nd) / 2
Pulleys
335027 - Composite Timing Belt Pulley 27T / 1 [ Front ]
335810 - Composite Belt Pulley 20T / 1 [ 2-speed shaft ]
335828 - Composite Belt Pulley 18T / 1 [ 2-speed side ]
335859 - Composite Belt Pulley 19T / 1 [ Mid-center ]
335885 - Composite Belt Pulley 25T / 1 [ Mid-side ] *depends what you're using
335886 - Composite Belt Pulley 26T / 1 [ Mid-side ] *depends what you're using
Misc
972030 - Silicone O-rings 3x2 (10) / 1 [ Outdrives ]
981210 - Pin 2x10 (10) / 1 [ Hub outdrives ]
965050 - E-Clip 5 (10) / 1
965070 - E-Clip 7 (10) / 1
901303 - Hex Screw SB M3x3 (10) / 1
* Rechecked all my figures and came out a bit more than I initially calculated. The only part I added was 333310 - Composite Rear Upright
Front
Rear
Belts
Clutch
Diff Parts
Pinion Gears
Spur Gears
Pulleys
Misc
#726
NorCal Hobbies ( Union City, CA ) just got them in stock today .
#727
Originally Posted by LORD SHADO
do you need all this jest to fix the x ray n1 to make it race worthy. thats crazy buy the r40 its a champion racer right out of the box.
#728
#729
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Now I can understand why you have issues with the moderators at the Team XRAY site.
easy does it....Don't forget,this is the newest member of the X ray team...and will be here to ask all the pertinent questions of you guys......(rather than the r40 thread..)..
#731
My NT1 ???
is it mine? ^^
look receiver case
look receiver case
#732
Stormerhobbies has 6 in stock at $399.95
#734
Originally Posted by gansei
is it mine? ^^
look receiver case
look receiver case
Receiver looks very good!
Is that yellow serpent springs? I think that's too soft mate!
#735
Originally Posted by Z00M
Gansei has gone to XRAY??
