Team Losi JRXS Type-R >
Like Tree52Likes
Old 01-07-2008, 11:02 AM
  #6196
metalracer2's Avatar
Trader Rating: 20 (100%+)
hey does anyone have a good asphalt setup theres only on carpet track in my area and they race on sunday and i can race sunday
metalracer2 is offline
Old 01-07-2008, 11:15 AM
  #6197
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
try hodge's reedy set up
Marcos.J is offline
Old 01-07-2008, 04:48 PM
  #6198
yyhayyim's Avatar
Trader Rating: 26 (100%+)
the losi website only seems to have Todd's ROAR nats set up...but I cant find the 07 RROC set up
yyhayyim is offline
Old 01-07-2008, 07:25 PM
  #6199
i cant ssem to find any of his setups on losi website
Old 01-07-2008, 09:07 PM
  #6200
Yeti35's Avatar
Try this site: http://www.petitrc.com/view_news.php?id=4620 .
Yeti35 is offline
Old 01-07-2008, 09:28 PM
  #6201
Hi All
I have been messing around with a friends car, it is unbelievably stable, but i am having trouble getting enough off power steering, this is indoors rubbers on asphalt.
Can someone offer some advise?
What adjustment will make it have a shite load of steering, started off with kit setup and have been changing a ton of things since.
Besercoe is offline
Old 01-07-2008, 09:35 PM
  #6202
Mike Haynes's Avatar
Try putting a shim under the inner blocks of the rear hinge pin, this will give you a bunch more entry steering.
Mike Haynes is offline
Old 01-07-2008, 09:42 PM
  #6203
I was looking at that, i have mostly been running the hinge pins in the low position (ie close to chassis) but tried them in the upper position last week, and the car felt a bit more lively, i was going to try and run the front in the low position and the rears high next week.
On setups the Roll Centre shows as high, does this mean the pins are in the top or bottom location?
Besercoe is offline
Old 01-08-2008, 05:22 AM
  #6204
When the sheet is marked high that means the pins are high.
Old 01-08-2008, 08:22 AM
  #6205
Registered User
hi Guys
some way back someone spoke about using a non losi turnbuckle on the front
of there r type instead of the bit of std thread bar
anyone know what it was as i can just never get my front camber correct
Geoff
Ben + Geoff Wal is offline
Old 01-08-2008, 08:23 AM
  #6206
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Just get one of the normal type r turnbuckles, Like the one ont he rear or on the steering.
L.Fairtrace is offline
Old 01-08-2008, 10:13 AM
  #6207
yyhayyim's Avatar
What do I need to do or what parts do I need to get to run 2 deg of rear toe? It seems the stock rear toe block is 2 deg, but the rear hubs are 1 deg offset, right? My Type R seems to have more than 2 deg, with the kit parts, so for 10.5BL on asphalt I'd like to try 2 deg or 2.5 rear toe...anyone know the parts needed to get this?
Thx
Yohan
yyhayyim is offline
Old 01-08-2008, 10:26 AM
  #6208
hamster778's Avatar
Originally Posted by Yeti35
No setup I have seen has used this position, so try it out and get back to us.
Does anyone know the Theory of ackerman
Longer outer links with a shorter drag link. What effects am i looking for
Cheers
Tim
hamster778 is offline
Old 01-08-2008, 10:27 AM
  #6209
Fastforward's Avatar
Originally Posted by LucentOptics
Where do you get that spur gear and gear mount?
You have a PRS spur gear adaptor in the stuff I sent with the car.
Bob
Fastforward is offline
Old 01-08-2008, 10:51 AM
  #6210
Matt Howard's Avatar
Thx
Yohan
The chassis has 1 deg built in and the kit rear toe in block is 2deg, so built per the kit you get 3 deg toe in. To get 2 deg you need to run the 1 deg rear block.
Matt Howard is offline
