Team Losi JRXS Type-R
#4847
i was breaking rear turnbuckles for a while too. are you running your arms back or forward? i was running mine back, but when i moved them forward, the breakage went away. the turnbuckle is at a pretty good angle backward if you run the arms back. i think that angle at an impact can cause the turnbuckle to rip out of the ball cup.
#4850
Hey Marcos,
I see your one chassis has no weight and the other has half an elephant on the left side what gives?
#4853
#4855
Apogee Magnum 3800 mAh Battery Pack
Hi guys,
Did anyone here running their JRXS type R with Apogee Magnum 2-Cell or 3 - Cell 3800 mAh Battery Pack?
Need to know if it will fit in the battery compartment or only the Orion lipo pack can fit in?
Advice appreciated. Thanks!
#4857
guys i need a little help here. i would have posted in the jrxs thread BUT its not as active as this one, but it resembles it anyway... my question is this, HOW do i adjust or tighten my diff with out taken the diff assembly out of the car, i looked at the diagram and the diff screw is inside the tube, is there a tool i need to adjust it its vertually impossible to adjust it with a regular screw driver. is that screw inside the tube the screw i need to adjust the diff with. is there a way to adjust it with out taken things apart. please help
#4858
I usually use an exacto blade or long body clip to slide into the screw head, just stick somehting in there to hold it, and turn the wheel on the oposit side.
#4860
Or you can use a small flatblade screw driver to tighten it with as well. Just stick the blade in the screw from the side and just do as the previous poster said. There is no need to tear anything apart to tighten a diff on either car.
