Team Associated TC5
#8611
Regards
#8614
Do you plan on getting a tc5f or tc5r or a tc5? The F and R version come with everything you need. The tc5 was lacking a few things but still a good car. I own both the F and R and both came out of the box with everything i needed. I bought some losi off road pistons because most of the set ups called for them. For the rubber car i also purchased a one way but that was a preference type of upgrade for my rubber car. Many people run the slipper spool (for Rubber) which is included in both the F and R kit.
Regards
Regards
#8615
Suspended
Some more pictures of the bulkheads on and off the car..
Off Car
Nick
Off Car
Nick
#8618
When trying to obtain 3 degrees of toe in for the rear, is there any difference between putting 3 1 degree shims in the rear and none in the front as opposed to 4 in the rear and 1 in the front? I am trying to follow the setup of one of the local racers for a starting point and he says 3 in the rear is a must for our track...
#8619
#8621
Finished building my TC5R. Felt that the motor screws are short and weak
and will eventually strip because of the short threshold. So I changed it to
longer titanium screws. Now Im planning to change the 8 short screws of
the suspension holders to longer titanium ones.
Is this ok?
Is this ok?
#8623
Is this ok?
Is this ok?
