Like Tree130Likes
TA-05 ver.2
Old 12-17-2009, 11:35 PM
  #466
Pingers's Avatar
Originally Posted by Skitee
Correct the Ver.II kit does not come with sway bars
I ordered two sway bar kits TAM53842 (one from hong kong & one from cali) because I didn't feel like waiting for the one from Hong Kong - if anyone is interested in it. I should get the one from Hong Kong sometime next week. I'd sell it half price, unopened.
Pingers is offline
Old 12-17-2009, 11:40 PM
  #467
tom_chang79's Avatar
Trader Rating: 13 (100%+)
Thumbs up
Originally Posted by gashuffer
Some updated pics of my v.II
That's just awesome. It's like a TA05 v2 MS kit now!!! Did you buy those pieces individually? I personally can't wait for that upgrade kit to come out, hopefully, Tamiya will keep the price to be less than the kit itself was...
Looks like you went full aluminum on the front hinge blocks... Which one did you use? Did you get the kit's setting:
1xa-1a(2 pairs)
1A (1)
1D (1) <-- This one shows up int he picture...
tom_chang79 is offline
Old 12-18-2009, 02:18 AM
  #468
Akudou's Avatar
Was preparing my chassis for a drift race this coming weekend when a horrible sound came from it. At first it sounded like the center pulley might have been chewed once again but after inspection it doesnt look like it so i decide to strip the centers apart. To my horror, the cantrilevel shaft wouldnt budge. So after some light hammering i manage to pry it off and upon inspection, the shaft seems to be worn. Dab a little anti-wear grease and slide it back on while checkin my pinion, spur, pulley and belt hoping that it will last me for this 2 days in which we have 40 cars in EP Drift Touring. 6 cars are belt-driven while the rest are all shaft driven. Format of the race are 4 qualifying heats of 5 minutes per heat. Hope all goes well for me this time around.
Here is the shell i am using for the race.
Akudou is offline
Old 12-18-2009, 02:25 AM
  #469
gashuffer's Avatar
Trader Rating: 48 (100%+)
1xa-1a(2 pairs)
1A (1)
Yeah I got everthing from Hong Kong, I just had to I even enquired with Tamiya about a carbon v.II chassis and they said that they are going to release one but didn't have a date. The suspension blocks are the same as the kit setup.
gashuffer is offline
Old 12-18-2009, 02:30 AM
  #470
What's a cantrilevel shaft? I want to keep an eye on mine too if you can explain what you mean...
I'm waiting for Speedtech to stock some parts, not sure what Jeff is planning to stock. I'm thinking of hitting up rcmart and just get it done with. Meanwhile, get some new M-Parts tree since one of my 1XA-1A blocks are somewhat busted... A hard crash and the pivot ball in the rear left arm pulled out, actually more like RIPPED out of the hinge blocks... That's why I'm hoping going aluminum would prevent that and just let the impact stay all in the arms. I rather replace an arm, which are supported at my local track, than the M-Parts, which are not...
Old 12-18-2009, 02:40 AM
  #471
Akudou's Avatar
Its the shaft that holds ur spur, spur holder and pulley
[QUOTE=tom_chang79;6735090]What's a cantrilevel shaft? I want to keep an eye on mine too if you can explain what you mean...
Akudou is offline
Old 12-18-2009, 02:42 AM
  #472
Whoa, have you guys seen this?
http://www.stellamodels.net/catalog/...oducts_id=3762
It's 3Racing's TA05 chassis, version 3.0!
I wonder if 3Racing's 3.0 = Tamiya Version 2?
Old 12-18-2009, 02:44 AM
  #473
Akudou's Avatar
Yes i have it seen it here already. Dont think its for our V.2 chassis.
Akudou is offline
  #474
[quote=Akudou;6735102]Its the shaft that holds ur spur, spur holder and pulley
Wait, isn't this shaft riding on bearings? How did it get jammed?
Old 12-18-2009, 02:47 AM
  #475
Akudou's Avatar
Yes it is. From the looks of the shaft, it looks like its been very tight there cos i see the shaft somehow like being chewed on
[QUOTE=tom_chang79;6735106]
Akudou is offline
Old 12-18-2009, 03:06 AM
  #476
Are your bearings worn out causing the shaft to wobble because of a lot of play?
Old 12-18-2009, 03:14 AM
  #477
Akudou's Avatar
Funny thing is i checked both bearing and they are fine. The shaft is not wobbling. Cant seem to find what is cause the shafts to be tight and worned. After greasing the shaft and running it once more, it sounded well. No more crunching sound. Might be im having so much torque on my motor that the center shaft seems to be really dry and cause the wear on it
Akudou is offline
Old 12-18-2009, 03:18 AM
  #478
What motor and gearing do you have in there?
Old 12-18-2009, 03:23 AM
  #479
Akudou's Avatar
Ezrun 9T Brushless, 100t (64P) spur and 0.4 steel 29T pinion. FDR- 7.08
Akudou is offline
Old 12-18-2009, 05:42 AM
  #480
TwoTone's Avatar
Trader Rating: 12 (100%+)
No it's their version of the chassis. They've made more than one conversion, this is the 3rd one. It has nothing to do with Tamiya's version numbers.
TwoTone is offline
