Hpi Pro 4
where can I find a set-up for a 27 turn motor on carpet?
any help would appreciated.
Trader Rating: 22 (100%+)
Originally Posted by Essnowyt
dontfeelcold - Did you ever fig out your understeer problem?
Snowy.
Snowy.
@chitae:
Send me your email adress, the files if got are too big to upload them.
Originally Posted by Mach10_shooter
I'm selling my Pro 4. If your interested please have a look.
http://www.rctech.net/forum/showthread.php?t=78497
Originally Posted by dontfeelcold
Not yet. castor blocks are on the correct sides. Im going to rebuild it on friday to run on sunday, I will see what happens.
@GCT69:
You have an email....
a million tnx from KY, USA
I don't know how to write German but here goes nothing,
ayn beer bitten, at least it sounded right.
gct69
gct69
passt scho
can't seem to open the file, it says there is an error.
I'll make a screenshot and email it...
Edit:
You got an email....sry, pics are too larg to upload them...
If somebody needs a Setup "made in germany", send me a email.
Edit:
HP73522 - Differential Screw & Heavy Duty Nut 2mm Set
Yep it fits the normal Pro 4. On first impression the diff nut seems much better, it's all in one with the plastic holder so it's not as awkward to build the diff and when you screw it in it seems much tighter. One thing I have noticed though is that the screw looks exactly the same.
73522 PRO4 DIFF SCREW & HEAVY-DUTY NUT
Thanks!........ I guess I'll try it again!
It was the right number it just had the "HP" in front of it to show that it's a HPI part. I took it straight from my Mirage Racing newsletter (the distributor of HPI in the UK) and they use the prefixes for different companies so none of the part numbers clash.
