Hpi Pro 4
#4696
Originally posted by lazyboy
im only scared of breaking those beveled gear, since my lhs/track doesnt have any, at least form what tsr6 has told me
lazy:
lazy:
Since I started running the PRP gear plate, I haven't been worried about them.
#4697
Droop
Hi Guys
I have just download Hara setup sheet from the net, and one thing i don't understand is why the l/r rear droop is difference? Can anyone of you help me? Thank you!
#4698
Registered User
New Hop-up from Excel. Upper arm mount brace.
#4699
Registered User
Pic2
#4700
oh, so those just go over the stock ones
#4701
Registered User
Yap!
#4702
when i first saw something like that on haras car, i thought it was the whole thing
#4703
Those make much more sense than a chunk of aluminum!
#4704
Re: Droop
Originally posted by Newbies
Hi Guys
Hi Guys
#4705
Frank Mckinney, can you please check your pm? Thanks.
#4706
The suspension mounts on Hara's car are clearly all carbon fibre and do not fit on top of the stock mounts.
In this pic you can see that Hara has used a locknut to hold the pivot ball in place:
The carbon looks pretty thick though, looks like it's about 5mm!
#4707
hmm...hara's CVD's dont look shiny....do you think he maybe using plastic ones because the ali ones bend???
not very likely but just a thought
#4708
In general, if your car is setup well for mod, would it be safe to say that it will work well in Stock also? Just wondering because this weekend I ran the car with some slight changes for stock and it was planted. But in 19T, it was all over the place which I thought was quite odd. So I figure if I setup the car for mod that it should be good no matter what class I run...does this sound reasonable?
