TRF101
#857
Ok thanks yeah I'm running the same spur/pinion set up, is there any other spring that works as long as it is soft like the tamiya red? Also does anybody know how to remove the pits from the black tamiya wheels. I want to get the exotek wheels for them to get me close to that 190mm mark.
#858
The best way I have come up with. Is to get a baking sheet. Then lay some foil down on it. Put your wheel/tire combo on there. Put it in the oven at about 400 degrees and just bake them off. When you pull them out of the oven. Use some grill tongs and something to press the wheel down while pulling up the tire with the tongs.
Its crazy. But it works. The wheel will warp a little. Just enough to where the bearings will be a snug fit inside. Also another note. You might try elevating the wheels off of the foil. That way there's no burnt ring around the sidewalls.
#863
Rsector wide track conversion kit for the F104
#865
Anyone having trouble with the diff slipping? If I tighten it enough to stop the slip it starts to feel somewhat notchy. I remember reading about the bearing below (please see link below) but just can't find the thread. If anyone has knowledge or experience adapting that to an F104 can you please share.
http://www.tqrcracing.com/shop/produ....asp?p_id=1137
#866
I save the inserts by taking a hobby knife cutting the bead. Thus remove the tire and insert before soaking the rim in acetone to remove the bead.
#867
#868
Yes, I can recommend going with this bearing to replace the existing bearing. it makes the diff a lot smoother. I use associated black grease and pack it on the thrust bearing. Using this bearing also cut's down on maintenance and I have also found allows the diff to be adjusted more to suit the conditions. Just remember to change the disc inside the diff from () to )( when using the thrust bearing.
#869
#870
anyone know which part number i need to get BC15? it is the ball socket mounted on the upper carbon plate - Tamiya (3404021)
http://www.petitrc.com/reglages/tami...101_Manual.pdf
Pg11
Also, BA13 looks out of stock. Tamiya (19808245)
Pg11
