Like Tree3Likes
TRF101
Old 10-09-2013, 02:56 AM
  #826
mingnon's Avatar
Originally Posted by PDR
Matt - I think I have a spare F104 carbon axle, but not sure if it's the same as what you need. If it is, let me know
Thanks Phil, the alloy piece on the end of the shaft is whats bent :-(, tamiya list the axle as one part (alloy and carbon shaft)and i havnt had any job seperating the shaft yet
Will let you know
mingnon is offline
Old 10-09-2013, 03:32 AM
  #827
Ph3nyx's Avatar
Hello
you can use a f104 carbon axle and a f104 aluminum diff instead , but it's more expensive of course. (then you can run at least)
Ph3nyx is offline
Old 10-09-2013, 04:05 AM
  #828
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Will let you know
Originally Posted by Ph3nyx
Hello
Ok. Matt - drop me a note if you want to. I also have spare diff assembly. It's missing the diff rings. Probably won't be racing Tuesday night due to a school meeting, but you could always drop in to the State Titles
PDR is offline
Old 10-16-2013, 04:09 PM
  #829
Csaari77's Avatar
Trader Rating: 35 (100%+)
About to get my car on the track for the first time. Does anyone have a starting setup for low-medium grip carpet. The track is fairly small and technical. I'll be running the Tamiya/Pit tires.
Csaari77 is offline
Old 10-18-2013, 02:40 PM
  #830
I've heard that there will be a second run on the production of this car in november.
It's mentioned by Fred Medel (atleast i think that's his name) of tamiya usa.
That's good news for spare parts.
addicted2blue is offline
Old 10-19-2013, 11:30 PM
  #831
Marklas's Avatar
Any that have tester the other pivot link positions?
Most still just run the standard configuration here.
Marklas is offline
Old 10-21-2013, 11:06 AM
  #832
As we have a couple of races with a silvercan motor and yesterday i was trying to fit the silvercan in the car and to my surprise this motor doesn't fit without using a dremel or file on the motormount.
I've already ordered me a second motormount to be able to use the silvercan motor and still have a spare motormount
@Marklas,
I'm planning to do some testing with the side links, just need to find the time for it
Old 10-21-2013, 11:35 AM
  #833
Csaari77's Avatar
I got my car on the track for a few shakedown runs this Saturday after letting it collect dust for the past 4 months. I used the kit setup on our small med grip carpet track just to see how it would handle.
I was pleasantly surprised how hooked up the car was the minute it hit the track. The rear end was very planted, a little to much because it was pushing in the sweeper at the end of the straight, but the car was amazingly stable through the rest of the track. I know it has been said before, but I could get on the throttle much earlier and harder than I ever could with my V2.
The next outing with the car will be our club race in two weeks. I need to drop the front ride height, it was at 6mm with the kit setup, and dial out the brakes in my ESC and then really give the car a proper test.
Csaari77 is offline
Old 10-21-2013, 02:33 PM
  #834
shadowracer24's Avatar
I found on mine that when I moved the link to the inside hole on the motor pod it helped mine hook up better on a low to med. grip asphalt track. Have not had a chance to try out carpet setups yet. still in the middle hole on the chassis.
shadowracer24 is offline
Old 10-22-2013, 10:57 AM
  #835
Jorge T's Avatar
Trader Rating: 14 (100%+)
I've tested all 3 settings on carpet using pits 572/571 and liked the outside link positions the most.
The inside link position gives the most traction but made the car push mid corner out.
The middle position I felt the steering was numb and would push going out of the corner.
The outside position gave most steering going in and out of corner.
I also tried middle on chassis outside on pod but lap times were faster with the links to the outside.
Jorge T is offline
Old 10-23-2013, 11:00 AM
  #836
TENCHO's Avatar
anybody have a new or used TRF101 for sale or trade? email me, [email protected]
TENCHO is offline
Old 10-27-2013, 07:16 AM
  #837
godzukihop's Avatar
Trader Rating: 32 (100%+)
Ran my TRF101 for the first time yesterday and loved it. I picked up almost a full second a lap over my previous F1. This car gave me the confidence to go faster and just push it that much more.
I just have 1 question. Anyone know if the Tamiya McClaren body kit will fit on the TRF101?
godzukihop is offline
Old 10-27-2013, 08:37 PM
  #838
macavant's Avatar
Trader Rating: 65 (100%+)
The McLaren MP4-24 body ?
Some trimming of the front nose section to allow for the upper arms, and the rear side pod to clear the side links and spring perch.
macavant is offline
Old 10-27-2013, 09:13 PM
  #839
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
We have 6 on order with Tamiya as soon as the next production run starts, 3 of these are spoken for already, and I am willing to order more if needed
BP SHADOW is offline
Old 10-28-2013, 03:09 AM
  #840
godzukihop's Avatar
Cool, now that looks HOT.
