Like Tree248Likes
Xray XB4 thread
Old 04-24-2015, 01:50 PM
  #8071
Trader Rating: 43 (100%+)
Originally Posted by suzukipro
I think I have a workable option here, I cut some lexan pieces to fit the brace and aligned things up the best I could putting some ca glue on the broken area and sandwiched it between the lexan on both sides (top & bottom)then tightened it up in a vise and waited for it to dry. It seems pretty sturdy already, but I'll drill a hole on either side of the break and run a screw/nut in to add support to the lexan. I'll post pics when I'm done and I run saddles in this car which just works better where I race.
Suzuki,
Nice work as you pulled out your inner McGyver. Not sure if you got my PM, but just incase a friend of mine said that loctite 410 works amazing in fixing broken CF parts.
Good luck at your races brother.
Norse is offline
Old 04-24-2015, 02:30 PM
  #8072
suzukipro's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Norse
Suzuki,
Thanks for the tips Norse, I did get your PM and it helped lead to the repair pictured above. Hopefully it holds up at the track tomorrow (last race of the indoor season) as the replacement is about a week out yet.
suzukipro is offline
Old 04-24-2015, 04:23 PM
  #8073
Good luck tomorrow. I think your fix will get you through the day. Have a great night my friend.
Norse is offline
Old 04-24-2015, 07:14 PM
  #8074
Im confused as hell. I want to run yokomo rims that have a 12mm hex. Can anyone tell me what size hex adaptors I need so Ill still have the same track width on a '15 spec?
Glarke is offline
Old 04-25-2015, 06:30 AM
  #8075
advpball's Avatar
Trader Rating: 30 (100%+)
What besides the stock body fit the 2015? What's everyone running?
Small indoor track 50 ft straight and tight.
advpball is offline
Old 04-25-2015, 08:33 AM
  #8076
JEFF.777's Avatar
I plan on picking up a 2013 could someone please tell me what i need to convert it to a 2015? thanks in advance
JEFF.777 is offline
Old 04-25-2015, 08:59 AM
  #8077
rcgod's Avatar
http://www.rctech.net/forum/13908067-post7589.html
rcgod is offline
Old 04-25-2015, 09:02 AM
  #8078
JEFF.777's Avatar
Was hoping to get part numbers
JEFF.777 is offline
Old 04-25-2015, 09:06 AM
  #8079
JEFF.777's Avatar
Whats the front x brace???
sAlso how many bevels would i need?
And im wanting to do saddle so please someone help because that doesnt help at all..
JEFF.777 is offline
Old 04-25-2015, 10:28 AM
  #8080
rcgod's Avatar
Part numbers are in the manual.
https://www.google.com/url?sa=t&sour...s1XSBkbb9ZIiVQ
rcgod is offline
Old 04-25-2015, 03:24 PM
  #8081
bd581's Avatar
Can anyone tell me if a 35T pinion will fit with the 78T optional spur or am I going to have to modify a smaller spur to get similar FDR and not be able to use the centre diff when running 17.5T Stock?
bd581 is offline
Old 04-25-2015, 03:36 PM
  #8082
whats the best diff oil to use for the center diff running on a low bite track
DIRT DIGGER is offline
Old 04-25-2015, 03:57 PM
  #8083
Trader Rating: 15 (100%+)
What are you guys using for chassis protection? Does anyone make '15 specific protective chassis sheet?
HeavyD99 is offline
Old 04-25-2015, 04:20 PM
  #8084
Arigato's Avatar
I've tested 100k, 300k and 500k and so far the 500 works the best for me on a tight, low/med traction track. Running saddle packs as well.
Arigato is offline
Old 04-25-2015, 04:22 PM
  #8085
Arigato's Avatar
AE chassis protective sheets for B44. They have to be cut to fit, but after the first one you'll have a template for more.
Arigato is offline
