Like Tree2Likes
Xray T4 '13
Old 08-06-2013, 03:26 AM
  #4561
chasingthepack's Avatar
Originally Posted by jaywestwood
Hey Richard,
I'm guessing this was at west London?
The track is so bumpy so we are all running more droop to stop this happening. .5mm is all that is needed
Cheers,
Jay
thats .5 up travel,right?ill try that next time jay,cheers
id never thought of so little droop,but yeah makes sense
you ok now after the crash?
chasingthepack is offline
Old 08-06-2013, 03:46 AM
  #4562
heretic's Avatar
Originally Posted by Bishop
It's going to be lite, I never remember to weigh a car at that stage for some reason, all I know is my new T4 weighs something like 100 grams less than the Photon EX it's replacing, which is likely good and bad for me, cause for some upcoming events I'll need to add something like 40-50g to it.
Originally Posted by hotrod1933
just checked car at home.
508 gms it has graphite arms, ecs, alum steering arms (30 2526 COMPOSITE DUAL SERVO SAVER ARM) and low friction belts. none of which would make a huge difference from stock weight wise.
it's a lot lighter than i thought it would be.
Bishop: around 100 grams ? Hard to believe. 50 grams would already be huge. For instance my empty Photon ( not EX ) is around 520grams ( with steel hardware all around and 4 aluminum dogbones). And I don't see the EX being much different; if anything it could well be lighter than that.
hotrod: Thanks a lot for taking the time to weigh the car. Actually, considered all has that's been said about the lightness of the T4, I'm kind of disappointed.
heretic is offline
Old 08-06-2013, 05:19 AM
  #4563
Skiddins's Avatar
Skiddins is offline
Old 08-06-2013, 06:59 AM
  #4564
Bishop's Avatar
The EX is a heavy car out of the box, I just weighed the one I stripped the other day to build my T4, it's seriously 553 grams, right now it has the alloy bones all around, and the stock lite spool with stock steel outdrives.
In race trim at a recent meeting my EX was well over 1400g with a front diff in it (from memory near 1420g I think at one point), when I weighed my T4 at it's first meet with some foams on it (it's a local club thing), the scales showed a tiny bit under 1300 grams, even accounting for the lite foams, with maybe a 40-60g step up to rubbers, I'm still looking at a 60-80g difference between the cars.
I know when I got the EX after having the original Photon, it seemed heavier in race trim, and I suspect it is, T4 though my bet is it's one of the lighter cars around.
Bishop is offline
Old 08-06-2013, 08:10 AM
  #4565
when wil the new xray t4 2014 Available
peter. is offline
Old 08-06-2013, 08:24 AM
  #4566
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Expect late October to early November timeframe.
Dan is offline
Old 08-06-2013, 08:25 AM
  #4567
heretic's Avatar
Ok, my bad. I guess it's one more reason to stay away from T.O.P. from now on. At least the TCs.
I don't have any numbers in mind but the weight difference between rubber and foam can be massive. The set of Ride 32's I have on my desk right now weighs in at 110g.
heretic is offline
Old 08-06-2013, 02:44 PM
  #4568
reg
What will the changes be on the 2014?
reg is offline
Old 08-06-2013, 03:01 PM
  #4569
Skiddins's Avatar
Looks like pivot blocks and chassis but we won't know until it's offically announced.
Skiddins is offline
Old 08-06-2013, 03:58 PM
  #4570
What would you guys consider to be the most important spring packages to get for carpet racing? High grip on our weekend races, and low to med grip for wednesday "Club" races? 17.5 stock sedan..
Boostinswifty38 is offline
Old 08-06-2013, 04:12 PM
  #4571
2.7/2.5 will give you a nice balance on carpet in the stock class. Or for a softer setup I like to run 2.5/2.5.
Danny-b23 is offline
Old 08-06-2013, 05:49 PM
  #4572
hotrod1933's Avatar
Default general driving help
this is more a general driving help question rather than setup.
this is for 21.5 blinky TC and last night 2-4 spread in a heat was 0.5 over 5 mins so a little in lap times makes a big difference.
My fastest laps always seem to be early on in the race say lap 2-5 usually when i feel i am finding my way and not driving near the limit. As I get what feels faster times drop off by up 0.5 I know this is the way I drive and slower can be faster. For instance i was scrubbing in a brand new set of green tyres once and just cruising around for about 5 laps knocking of the seam and did my fastest lap that day by 0.8
What do people do to things like steering expo or throttle to maybe slow down the way they drive. one guy last night suggested slowing down steering so the car reacts slower (yet to try) or is it more just general smoothness.
hotrod1933 is offline
Old 08-06-2013, 05:59 PM
  #4573
bvoltz's Avatar
Trader Rating: 44 (100%+)
What he is saying is to adjust the speed of the servo, in the radio...
My first comment is yes your fastest laps will be at the start, when the battery is at the high point.
The other thing you can do is just relax and have fun.. this should slow you down a bit... Your goal is to not touch the pipe, this will make you drive a bit slower... The key to a good run is "consistent" over the whole run... look at your top 5, 10 and 20 laps... the goal is to have them be as close as possible... your laps will get faster if you focus on "Consistent" runs.... Faster is a by-product of consistent....
bvoltz is offline
Old 08-06-2013, 07:37 PM
  #4574
"Go slow to go fast". There's some truth to it. However, I've noticed with myself and some other racers, that once you reach a certain point of consistency, you can end up going slow to go slow.
Within a given round (to take out track evolution differences), how far off the pace of front-runners are you?
Are you using the same tires? Same tire age? Same tire prep?
What is the difference between your fastest lap and your top 20 average (consistency)?
If you're more than a second per lap off pace, and your consistency is more than about .4 sec on a good run, then chances are driving improvements will make more of a difference, assuming you have a decent setup. If your consistency is good, but you're pretty far off pace, then it's probably a combination of setup and driving.
Some things that would be helpful to know are track type, grip level, layout, tires.
In order of importance, the general things that have helped me get on pace are:
1) Consistent car setup. This was hard with the Mi4's, because they tend to lose their setup over a run, especially if I hit stuff. Just getting the car to work the same way every run too me 2 years to learn how to do properly, and made a big difference in being able to drive it the same way every run. Re-setting hinge pin blocks, droop, alignment, bleeding shocks, making sure nothing is binding, consistent tire prep, etc...
2) Drive consistent. Try and drive every lap the same, even if it's not the fastest way around. If you're having trouble driving consistently, no matter how hard you try (and you don't just suck ) it might be a setup problem. A big indicator is if you find yourself watching the car instead of watching where you want to put the car. If you feel that you have to watch the car, then the car is probably not doing what you want it to be doing, and a setup change might fix that. The first job is to get the car to behave well, getting rid of things like inconsistent turn-in, or abrupt changes to it's attitude when you get onto the power.
3) Don't overdrive the car. If you have to slow down more to drive a tight, consistent line, then slow down more. If you try to force the car to do a faster lap time, then you won't notice the things that are keeping it from doing that lap time, you won't know what setup changes to try, and you'll have bad consistency and think you're just not a good enough driver. Once you drive within the limits of the car, then it's easier to understand what the limits are, so that you can try to make setup changes to raise them. Do you have to slow down a lot to get a tight line into the corner? Look at changes to increase corner-entry steering. Are you getting into the corner well, but you're falling off the apex mid corner? Then look for more mid-corner steering. Are you getting to the middle of the corner well, but you have to wait to apply power to keep it from going wide on exit? Then look for more corner exit steering. It's very very hard to break it down like that if you're already off line at the start of the corner, because you're just flat out pushing too hard.
4) When in doubt, drive a tight line and shorten the track. The slower the corner, the more you want to shorten the track, because when you're going slow, it takes longer to cover extra distance. When you're focused on driving the tight line, you'll start to notice what is making it hard to drive the tight line, and that will guide your setup changes.
5) You still have to push, though. In about the middle of this past carpet season, when I was about .8 seconds off the pace, but with good consistency, I had a good (for me) qualifying run going. Then I rolled off a dot, and then got tangled up with some traffic, losing probably half a lap, and ruining the run (or so I thought). I got really frustrated, told myself "f' it, I've got nothing to lose now", and just started railing the car, driving it really hard. It was sloppy for a lap or two, and then the strangest thing happened: it started feeling locked in, and was just plain fast. I ended the run with a better time than what I was on before the mistake, consistency was still good, and my fast lap was like .4 better than I had ever done on that layout. That was the night I realized that I hadn't been getting enough heat into the tires, and that I needed to focus on setup changes that would let me drive the car hard into the corner on a tight, consistent line, while getting good rotation in the middle to drive out hard, and by the end of the season I was on the same lap as the front-runners, with fast laps within about .2sec, and good consistency.
Regarding messing around with the radio: I've been through periods of messing about with radio settings to try and make the car respond better, and I definitely don't recommend going that route. It's a Band-Aid. You don't want to slow down response, because that will make you feel less connected to the car, and make it harder to react to things like traffic. More servo and radio speed is a good thing. Messing around with expo to change the way the car reacts usually just leads to chasing your tail. You can adjust the way the car reacts with spring rate and shock oil, and get more rotation / steering with setup changes.
The only radio adjustment that I've stuck to is turning down dual-rate so that I only get as much steering as I need to get around the track. Too much lock punishes the front tires, can actually create understeer, and makes the car unpredictable through the corner.
-Mike
grippgoat is offline
Old 08-06-2013, 08:59 PM
  #4575
Trader Rating: 27 (100%+)
Most guys at our local track are running 2.3's all around. This is on a low-medium grip carpet track. Oil is usually around the 400s or so.
For higher grip weekends, you could look into 2.5's/2.7's all around.
hyujmn is offline
