Team Associated TC4
#6858
Originally Posted by Andrew Selvaggi
so the FT TC4 doesnt come with a bettery strap, does it come with some sort of tape to hold down the batteries, and if so does this mean that you have to keep using a new piece of tape every time that you put a new battery in??
#6859
stan
stan want to meet at C/H to tune the car, lunchs on me.
no club racing this week either, I like to get the car dialed so I can come at you guys,let me know, I LIKE THE SHOCKS did carl get the sameones. I just added bearing to the steering servo.
newera152
newera152
#6860
does any1 know were I can order the Vantage racing mat, Iwent to there site can't order it there,does any1 know.
newera152
newera152
#6861
Originally Posted by Chris Brown
What size spur gear are people running for stock. 64 pitch of course. I know it'll take up to about a 96 or 100 but I am curious as to what size spur gears to start with.
100T Spur Gear.
#6863
Losi rear hubs on a TC4
Tried this method at the weekend, but it did not feel right at all on the back
So I chicken out and went back to the asso hubs using the outer hole on the hubs with silver ballstuds inner hole with one washer on the brackets
I am running on Take off CS22 rubber on primafelt GT on an indoor track.
I tried the set up with silver ballstuds inner hole with one washer on inboard brackets and outer hole black ball stud & no washer on losi hubs. The idea being to get a flat parallel link for more grip.
The car seemed to hook mid turn, so I guess I need to smooth out the transition because I had too much grip on the rear.
Any ideas guys.
Any ideas guys.
#6866
Originally Posted by mark240973
Anyone tried losi rear hubs with rubber tyres?
#6870
Is there a "standard" TC4 setup sheet? I am new to on road racing, I raced a B4 and T4 offroad and I know they have "standard" setup sheets to start out with. I want something to start with.
p.s I will be racing carpet, foam tires.
And for the washers under the ball studs, what is the thickness of each washer? Are they the same washers used on the B4 and T4? I do not see a part number in the manual to use. Have seen a couple setups were they call for 3-4 washers, that just seemed liek a lot.
