Like Tree3Likes
Xray T4 2016
    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Old 03-05-2016, 01:24 AM
  #601
Barry_Hughes's Avatar
Originally Posted by yifuqiao
Can anyone share some experience with the flex settings on the motor mount ?
I think it is unclearly documented and I looked up all the possible X-ray setup book, they did it mention anything about.
I do see the settings are being played by X-ray team players, but they are far different from each other.
I need some help to set it according to my like, plz help.
Ed Clark aka Tryhard's findings on the motor mount screws posted in this thread
http://www.rctech.net/forum/14332907-post371.html
Barry_Hughes is offline
Old 03-05-2016, 04:40 AM
  #602
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Originally Posted by R Dodge
Honnestly here @ the roar nationals most of us are over weight. I know the 3 cars I'm wrenching on have 0 weight added and that's with avid studs and hero ti/Alu screws up top.
jlfx car audio is offline
Old 03-05-2016, 05:21 AM
  #603
Jamison R's Avatar
Trader Rating: 66 (100%+)
It think these are for the USGT and VTA classes I would assume. TC wouldn't need as much weight.
Jamison R is offline
Old 03-05-2016, 12:15 PM
  #604
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
My T4'16 is 1300g ready to run. I think the low profile batteries have a lot to do with it.
dr_hfuhuhurr is offline
Old 03-05-2016, 12:21 PM
  #605
valk's Avatar
Trader Rating: 13 (100%+)
I was 1320 with orca 6200, revtech 24k, hobbywing and savox. I like the idea of the brass weights but they prob ungodly expensive knowing xray. ill prob pick up the alu chassis before i spend on any of the other weight options with our club moving to black carpet in fall.
I remember having to add 50 grams to craigs aluminum t4 at the last big race i borrowed it heh.
valk is offline
Old 03-05-2016, 02:50 PM
  #606
B00t13g's Avatar
mod cars running 5000-6000 mah batteries will benefit most from it. What tires you run also makes a large difference in weight.
B00t13g is offline
Old 03-06-2016, 12:23 AM
  #607
T4 '16 ip 6000 cells, 24K motor, Tekin Gen 2 ESC, Sanwa receiver & Servo, std weight body, Ride wheels & tyres, I have to add 65g to make the 1350g BRCA min weight.
Old 03-06-2016, 03:53 AM
  #608
With a Motiv 7800 on Gravity tires I have to add 40g. It was the same with Jacos for Birds. Testing a Motiv 5000 had me adding another 70g. That is with the Avid aluminum chassis. These are also a nice tuning option for weight bias.
They will be excellent for VTA and USGT classes where it is sometimes difficult to find room to add weight.
R Dodge is offline
Old 03-07-2016, 09:32 AM
  #609
what does the angel stick do?
DOTMAN is offline
Old 03-07-2016, 10:08 AM
  #610
cwoods34's Avatar
Running XRAY's aluminum chassis I still had to bolt 70g of weight to the car for mod, so the brass arm mounts (specifically front) would be really convenient
cwoods34 is offline
Old 03-07-2016, 01:08 PM
  #611
Team EAM
Trader Rating: 79 (100%+)
I have them in stock. They also work on the Yokomo and new VBC car.
EA
EAMotorsports is offline
Old 03-07-2016, 07:17 PM
  #612
Team EAM
Got 2 xray Flex chassis left in stock!
EA
Old 03-08-2016, 04:20 PM
  #613
spu83's Avatar
Anybody running ARS ? When is best to use it ?
spu83 is offline
Old 03-09-2016, 08:23 AM
  #614
erchn's Avatar
Generally, when I see setups running it, and when I've run it, it's been on big outdoor tracks. On small tracks any advantage it can bring makes the car inconsistent, or at least feel that way due to the quick transitions.
erchn is offline
Old 03-10-2016, 07:45 AM
  #615
Any idea when the Brass pieces will be in-stock?
