Xray T4 2016
#616
#618
#622
Can anyone share me your experience with the xray flex alum chassis and xray non-cut alum chassis?
I saw xray drivers use both, but it seems to me , mod is running flex and lower power cars run regular alum .
#623
Does anyone know the dimensions of the PSS cylinder?.
Basically the length and the outer diameter.
I want to check if it fits my non-Xray big-bore shocks.
Or if anyone has the inner bore and inner length of the shock housing for the Xray shocks that would also be nice.
Thanks in advance!
Thanks in advance!
#624
The diff up basically adds a bit more roll in the front (due to CG stuff) which can add steering, because the car will carry more corner speed on higher traction levels.
You can have so much front traction that the car feels like it is coming to a stop or getting pushy.
#626
#628
What he means is that you might have to readjust the belt tension when moving from low to high or viceversa, just to make sure it‘s not overstretched.
#629
I meant the highest and lowest possible positions. It seems rare (to me at least) that I've ever had proper belt tension with the diff either fully up or down, and the more towards the middle the proper cam setting is, the less noticeable going "up or down" is, to the point that many guys probably don't care to mess with it.
