1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2900Likes
Old 04-07-2013, 07:49 PM
  #7606
Originally Posted by PROMODVETTE
F1Ultra guys... few quesitons
1.) Battery inline or lateral?
2.) Best rubber tire combo for carpet?
3.) Have you run it on foams? How did it work? Which tires did you use?
I like battery in line. Gives the car more steering and helps it transition left to right faster.
I race on carpet and use pit shimizu tires r1hards and f3softs. You might be able to use f1softs but they glaze at my track.
I have not tried foam tires on the ultra but I really should.
racer robert is offline
Old 04-07-2013, 07:56 PM
  #7607
Originally Posted by aarcobra
Sorry to not get back to you sooner, I actually got to race this weekend VTA & TC!!
With the GFX conversion to use the VTA stuff the F103, F109, and the Tech arms all come out at ~188mm, as close as I can measure. Rear is the same, I could widen or narrow the front a few mm with different hexes, I'm still using the 3R brake disks on the front. I think I can cut off a few mm of the upper a-arm where the two 4mm screws go thru and them bend the arms up which might give me a little camber too.
Yes I'm using standard VTA 26 and 31 mm front and rear wheels, tires.
ned
I
Thanks for the info Ned....keep us posted on your progress with the VF1 car!!
Team Lotus is offline
Old 04-07-2013, 08:22 PM
  #7608
Trader Rating: 70 (100%+)
What's a "F1Ultra"? Is that a conversion for the F103?
Yes
Thanks Robert!
PROMODVETTE is online now
Old 04-07-2013, 10:58 PM
  #7609
ShadowAu's Avatar
Can the RIDE R1 tyres be mounted on Tamiya rims?... I am preparing for an event and would like to run the same rims despite having a couple of different tyres I want to run
ShadowAu is offline
Old 04-08-2013, 12:01 AM
  #7610
wwddww34's Avatar
Trader Rating: 9 (91%+)
Hey fellow F1 racers, it looks like Sweep is getting into the F1 tire business. Check out this video of Sweep's F1 Tire Testing.
wwddww34 is offline
Old 04-08-2013, 01:03 AM
  #7611
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Not normally.
However, Ride make a set of rims that from a distance look a lot like the Tamiya ones. The R1 pre-mounts (26023) come on them and I've mixed them with Shimizu 571's on the Tamiya plated foam rims up front and you can't really tell from a distance.
I've got some Sweep F1 tyres coming in the post, so I'm going to try them on the plated rubber rims.
These are the Tamiya ones (when you glue 'em up, suggest you gently take away the paint from where you intend to glue the rubber ):
http://www.tamiyausa.com/product/ite...oduct-id=54400
http://www.tamiyausa.com/product/ite...oduct-id=54201
Just done a quick search and Ride don't seem to offer the silver rims on their own...
PDR is offline
Old 04-08-2013, 02:06 AM
  #7612
ShadowAu's Avatar
Originally Posted by PDR
Not normally.
I suspected as much... thanks
ShadowAu is offline
Old 04-08-2013, 08:26 AM
  #7613
Yes
Thanks Robert!
NP,
Originally I built the car with a transverse battery but the car drives so much better with it inline for my conditions. The electronics are much easier to locate with a battery transverse. I suspect across the chassis would be the way to go on a low grip surface but for carpet traction is not a problem and in-line works better.
Old 04-08-2013, 01:13 PM
  #7614
Originally Posted by aussierevo
that's a great effort.
can I ask what paint you used on the mirrors etc. I know the instructions say to use the PS60 spray, but when I used that paint on the plastic it went a dull red, not bright red.
I used multiple coats of the ps60. I did about 3 or 4 and still could be a little brighter. For an RC model I don't want too many coats of paint, but if this were a static model, I might try white first then do the red over that.
Also, for the body, I used PS60, then brush painted red latex paint into the creases. Then I backed the whole thing with silver, so it does not look like painted clear plastic body.
ic-racer is offline
Old 04-08-2013, 01:42 PM
  #7615
NP,
I think traction between our tracks are fairly similar. I have used setups on my TC from Mikes that worked excellent here.
Old 04-08-2013, 01:51 PM
  #7616
Marty Peterson's Avatar
Well here is my start of Manny's VF1 Lotus 49.
Right now I have it sitting on an old F103, waiting for my F104W, Still looking for Honda RA300 Decals, #14 is all I think I need, anyone? or I might do a gold and black lotus type livery or a red stripe. like the body in the background.
Marty Peterson is online now
Old 04-09-2013, 07:18 AM
  #7617
I was lucky to watch masami hirosaka racing F1 in Hong Kong last Sunday. He was using the new Yokomo F1 (Wide Format and Form Tires). Wide format and form tires is a preferred combination in Japan and Hong Kong.
Here are some videos.
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
alanchow is offline
Old 04-09-2013, 07:32 AM
  #7618
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
What a track !
RedBullFiXX is offline
Old 04-09-2013, 07:41 AM
  #7619
macavant's Avatar
Trader Rating: 65 (100%+)
Wide format + foam tires generate some awesome corner speeds in those videos. +1 with RedBullFiXX - that's a nice track.
macavant is offline
Old 04-09-2013, 08:32 AM
  #7620
Vyger's Avatar
Masami Hirosaka with an F1 car...AWESOME!
Thanks for the vids.
Vyger is offline
