CRC 1/10 Pan Car
#3661
How is track width adjusted with the SE kit? I see two sets of arm mounting holes to move the arms either forward or back for two wheelbase positions but I don't see any holes to move the arms in and out for width. Am I supposed to just shim the wheels?
#3662
For the SE, you have the option of dremeling off the tabs that are no longer needed with the narrower chassis plate.
The wide plate is great at a major event where traction goes off the scale. But, I would like to see a middle width FE plate at some point in time.
Bill
#3663
Thanks Bill. Sounds like I would need an option part to adjust the track width with my SE.
#3664
The wide plate does provide stability; but, you also give up a certain amount of steering response with it. Probably not an issue when traction is high. I only find it necessary to use the wide plate at a major carpet event when traction tends to get way up there. Currently have the narrower plate in all three of my WGT cars; and, the wide plate at the ready in my pit box.
Forgot to say that I routinely have to trim the front wheel wells a tad more for wheel clearance with the wide plate.
Bill
#3666
1/10th and 1/12th front ends only refers to the lengths of the king pins and related springs used on both sides. On a smooth fast carpet track I normally use the 1/12th setup. For asphalt, it is always the 1/10th versions. You can get the most used king pin and spring options for maybe $25.
A standard width FE plate comes with the kit and the #17403 wide reversed servo FE plate lists ($16 list).
With the #3348 long dual-mount upper arms ($4 list) you need a #3277 graphite cross brace ($15 list) (which is actually made for a 1/12th scale; but, is easily modified for use on your WGT car).
That's all of $60 for the above options; plus, add a #1776 adjustable brace ($17 list) for pretty much every option I use on my LE/SE's.
There were individual option parts for my TCs that easily cost more than that...LOL
Cheers!
Bill
#3667
I used the short ball cups on the shock of my new SE kit and I have excessive droop with no apparent way to shorten it. Are you guys using shock limiters (like fuel tubing) to limit droop?
Edit - I used a small section of fuel tube as an internal limiter and fine tuned the droop with the ball cup position and I got the droop I wanted.
#3668
All three of my WGTs have one o-ring inside the shock to limit the travel.
I believe the shock comes with an extra o-ring for this purpose.
Bill
Bill
#3669
I tried putting the extra o-ring in the shock and I still had about 3mm of droop with the ball cup screwed in all the way.
#3670
What the difference between these 2 springs?
http://www.tqrcracing.com/shop/produ....asp?p_id=1039
http://www.tqrcracing.com/shop/produ....asp?p_id=6877
I see they are both purple. But are they same rating? I know CRC had to switch spring makers And the new one is CLN3411. Reason why I am asking is that I have the older one CLN32995. I was going to use with that SG1 guy set up that everyone is using. But I wasn't sure if he was using the old one or new one. Can someone shine some light on this. I have some of the older springs and just want to know if there is a difference.
#3671
#3673
Per Brian Bodine (Slapmaster), get the new CRC center/side springs to be current with setups from team drivers.
Check Slapmaster posts for his take on the new springs.
Bill
#3675
