Hyper TT 4wd 1/10th Truggy Thread >
Like Tree48Likes
Old 10-20-2011, 09:50 AM
  #3196
NofriendsTaco's Avatar
Trader Rating: 53 (100%+)
Also...
anyone think a castle 4-pole 4600 motor with 16t pinion on the blue delrin spur will cause heating issues or would this be good? ESC will be an MMP.
NofriendsTaco is offline
Old 10-20-2011, 06:53 PM
  #3197
elex300's Avatar
Trader Rating: 110 (100%+)
Here is what I have so far. Please let me know if you see anything I did wrong and should change as this is my first electric kit. I know the servo is crap but the one I ordered won't be here till Monday and I want to test it out tomorrow. All input is very much appreciated.
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
Attached Thumbnails Hyper TT 4wd 1/10th Truggy Thread-p1016504.jpg   Hyper TT 4wd 1/10th Truggy Thread-p1016503.jpg   Hyper TT 4wd 1/10th Truggy Thread-p1016502.jpg
elex300 is offline
Old 10-20-2011, 06:58 PM
  #3198
Arigato's Avatar
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
I don't think your body will fit well with the esc in the back like that. I would put it on top of the servo and the rx in front of the battery tray. It's a fun kit!
Arigato is offline
Old 10-20-2011, 07:38 PM
  #3199
elex300's Avatar
The body dropped right on. I tried putting the esc on the servo but it would'nt fit with the fan on it. When my new dremmel shows up i'm gonna grind down the sides of the fan so it sits closer to the esc then i'm gonna move it to the servo. It will probably stay cooler up front. Thank you for your reply.
elex300 is offline
Old 10-20-2011, 07:58 PM
  #3200
Arigato's Avatar
If the body fits then run it! See what you need to adjust after some laps.
Arigato is offline
Old 10-20-2011, 08:12 PM
  #3201
RacerX20's Avatar
Originally Posted by NofriendsTaco
Also...
You should be fine if you've got a good battery.
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
Looks good to me. Are you going to race? 3800kv might be a little slow with a 14t pinion. But it all depends what you want it for. For a tight technical track that'll be okay.
-Tony
RacerX20 is offline
Old 10-20-2011, 08:24 PM
  #3202
elex300's Avatar
-Tony
Yeah I will be racing and the track is really tight and technical.
elex300 is offline
Old 10-21-2011, 02:08 AM
  #3203
ps71's Avatar
What wings fit on this truck? Dont like the stock one....
Thanks...
ps71 is offline
Old 10-21-2011, 02:11 AM
  #3204
.AJ.'s Avatar
has anyone come out with alloy front hubs for this yet?????
.AJ. is offline
Old 10-21-2011, 02:14 AM
  #3205
RacerX20's Avatar
Thanks...
Losi Ten-T
http://www.amainhobbies.com/product_...ware-Set-Ten-T
The holes line up, but they are larger on the Losi wing. Cut a thin slice of fuel tubing or use an A-arm shim or something to center them.
-Tony
RacerX20 is offline
Old 10-21-2011, 02:15 AM
  #3206
ps71's Avatar
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
My brother use to run the CC SW 3800 with 14t and that works just fine.
He did not even have a fan on the esc..
ps71 is offline
Old 10-21-2011, 02:18 AM
  #3207
ps71's Avatar
Losi Ten-T
-Tony
Thank you, looks a lot better with that wing
ps71 is offline
Old 10-21-2011, 06:08 AM
  #3208
Also this wing:
http://www.amainhobbies.com/product_...o-V-Wing-Black
AL3xGR is offline
Old 10-21-2011, 02:02 PM
  #3209
Trader Rating: 41 (100%+)
The Tekin RX8 ESC will work fine mounted on the servo,you just have to angle it slightly to clear the servo arm..
rifraf is offline
Old 10-21-2011, 03:33 PM
  #3210
Trader Rating: 73 (100%+)
I am going to start racing my 10tt on a indoor carpet track. What would be the best tires for this and where can I get them?
We have experimented a lot on our local carpet track and foams or proline striker II are by far the best.
Foams require a bit of work and a tyre truer if you can't find pre mounted.
At our track race rules state we must use stock wheels so premounts are not an option.
So the process is lathing of the wheels to remove regular tire mounting ribs, glue on tires, trim tire edges and then true to correct size.
Strikers just glue on - use associated truck foam inserts with them (asc7880)
mister_g is offline
