Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-19-2005, 07:45 AM
  #10366
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Arjen
Next sunday is the 4th round of the dutch nationals.
last sunday there was een kind of an pre race.
The car was pretty good and qualified 2nd.
but i found out that my car falls still in the corners.
So i need a little more corner speed and roll.
the setup further was good but with more corner speed and roll i could be a little bit faster.
my setup now:
Front:
50 oil 3 holes
asso blue 17.0 lbs
2nd outer hole on shock tower
outer hole on the lower arm
middle top camberlink
1.5 camber
0.5 toe out
one way
alloy pivot blocks
Back:
40 oil 3 holes
asso silver 14.5 lbs
3rd outer hole on shocktower
2nd outer hole on the lower arm
1.5 camber
3 toe in inboard
alloy pivot blocks
battery front inside
19turn element orion stock motor (hand out)
I thougt i could maby try roll bars but maybe that would change the grip to much.
Do you guys have a couple of tips for me what i can try?
Arjen
You may try using the alloy suspension blocks in the rear and go with 2º rear toe. Also try 40wt in the front.
Jon Kerr is offline
Old 07-20-2005, 02:34 AM
  #10367
bender's Avatar
Jon, I noticed in the Spool Benefits thread you mentioned that a one-way isn't relly suited to the Mi2.
Could you explain why? I've just put the Tamiya shocks on my car and my next item to get was going to be a one-way (if I continue to need more turn-in) - so I'm interested to hear about your experiences.
I've noticed that out of all the Mi2 setups on the net - only Teemu consistantly uses a one-way, in fact I don't think I've seen a setup of his without one
bender is offline
Old 07-20-2005, 06:36 AM
  #10368
STLNLST's Avatar
Trader Rating: 32 (100%+)
It's all personal preference ( IMO) Everytime Mo or I have put one in our cars it's been dialed. We have come to the conclusion that in stock and 19 turn we like the oneway but in mod it's nice to run the spool just for the brakes. Some like it and some don't.
STLNLST is offline
Old 07-20-2005, 07:03 AM
  #10369
PW
PW's Avatar
bender...I don't think it matters what car really, just the type of track. Most European tracks are oneway friendly and most USA tracks are not. Most of the euro tracks are very large and flowing and the USA tracks are smaller maze type tracks where you point a shoot. Wish we had some more tracks like the euro tracks
Almost all european racers that come to the US try the oneway, but always end up running the spool
PW is offline
Old 07-20-2005, 07:27 AM
  #10370
AdrianM's Avatar
Here are some pics of my new paint job. The car sure does hunker down ripping out of a corner with a 7x1 !
AdrianM is offline
Old 07-20-2005, 07:59 AM
  #10371
Jon Kerr's Avatar
PW hit the nail on the head. However, when I ran a Losi car, I liked the one way on almost every track I went to. It was easier to drive and handled better. The exact opposite has been true with the MI2. I know many of the other team guys also like the spool only. In the spool thread I should have made it more clear that it was my experiance that the MI2 didn't like the one way. Sorry for the confusion.
Adrian- Looking good. You do the paint?
Jon Kerr is offline
Old 07-20-2005, 08:20 AM
  #10372
TimPotter's Avatar
Trader Rating: 15 (100%+)
Adrian, you still race ?
TimPotter is offline
Old 07-20-2005, 08:30 AM
  #10373
AdrianM's Avatar
Didn't I bump you out of the 19T A-main at the last Tampa State Race....
AdrianM is offline
Old 07-20-2005, 08:38 AM
  #10374
TimPotter's Avatar
What is the saying... Blind Squirrel....
Well come on down here and run at our track :> I added a picture of my car too
Old 07-20-2005, 08:50 AM
  #10375
AdrianM's Avatar
I wish you could take a pic that would convey the horror of a 1/12th car hit hitting a cement block and decelerating from 35mph to 0 on 0"...lol!
AdrianM is offline
Old 07-20-2005, 09:49 AM
  #10376
turbodog's Avatar
Well, I'm sure you "bumped" someone in the race.
Paint job looks cool!!
turbodog is offline
Old 07-20-2005, 11:42 AM
  #10377
PW
PW's Avatar
Yes he does.... What a jerk for ignoring you
PW is offline
  #10378
rbboy's Avatar
Default HELP
PW/Jon Kerr/AdrianM:
what is the effect of the length of the Centre Track Rod on the steering assembly? definitely if i add length to it, my camber links would be shorter and vice versa... any track tips on this? what length do you guys use? hope you can help me out
Carlo
rbboy is offline
Old 07-20-2005, 05:13 PM
  #10379
Jon Kerr's Avatar
Yeah, no kidding
Jon Kerr is offline
Old 07-20-2005, 05:16 PM
  #10380
Jon Kerr's Avatar
Carlo
The center link will effect the Ackerman settings. You'll want to set it so that both bell cranks are parallel to each other and I honestly can't remember what the exact length is.
Jon Kerr is offline
