Like Tree26Likes
3 racing new F1
Old 10-23-2011, 05:49 PM
  #181
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by bertrandsv87
I want to get the car ready for all classes, stock or mod , with just a motor and gearing change . Also you are right about the slipping in mod that makes it easier to drive than a gear diff. I could never get my Nikko F1 gear diff to put the power down correctly with any mod motor more powerful than a 10turn brushed, and even then it did not last long . I already have a ton of ball diff hardware . None of my other cars have a gear diff, and I want to keep it that way .
My gear dif works flawless!
http://www.youtube.com/user/Mantiswo.../7/2gQfVTzJJNQ a high power motor with foam and a sticky track will end up in disaster. maybe with silver cans and maybe 13.5 but anything more than that will just end up in burned up pcs! or end up rebuilding every weekend. direct drive is not the same as IRS. that vid was 3s 17.5, the car now has a 4.5.
how can you compare a nikko gear dif to 3r's dif?
MantisWorx is offline
Old 10-23-2011, 07:08 PM
  #182
snoopyrc's Avatar
I'm with Mantis here. This is a substantial difference in quality.
snoopyrc is offline
Old 10-23-2011, 07:09 PM
  #183
The Nikko f1 pro web gears are made of steel, and have never been chewed up, but the forces flexed the plastic housing enough to cause the gears to lose contact. If the housing was also made of steel, then it could handle anything.
bertrandsv87 is offline
Old 10-23-2011, 07:14 PM
  #184
MantisWorx's Avatar
3r has a pretty good TC dif so im sure it will handle great!
Old 10-23-2011, 07:22 PM
  #185
I also want to point out that the Nikko f1 diff gears never blew up while running the car, but they made a loud popping sound when I free revved it . Also my Nikko f1 was much faster in a straight line than that F1 in the video, although it didn't handle as good at all....All that is in the past now that I've replaced the Nikko F1 with the FGX F1 !!! Can't wait to get it......
Old 10-23-2011, 07:25 PM
  #186
MantisWorx's Avatar
that is a 3s 17.5 boosted on a 230' straight clocked at 68 mph! i doubt you were faster than that!!
Old 10-23-2011, 07:34 PM
  #187
My Nikko F1 was a Novak 4.5 gtb geared 4.999fdr with 65mm rear rubber tires. I never clocked it, but no 8scale could catch it once I punched it . It must have been going 80+mph, but don't turn... With a 530watt/9000kv motor geared 4.99 to 1, and 65mm tires, you're looking at 85+mph...
Old 10-23-2011, 07:37 PM
  #188
I hope I could replicate that setup with the FGX, and hopefully it will handle....
Old 10-24-2011, 08:02 AM
  #189
How you can compare Nikko "some metal" gear diff with 3 racing? Nikko is only (not much) better toy, there is big difference in quality...
Anyway, if you want run car on straight 80mph+ you dont need independent suspension or differential... FGX was made for circuit, for better turning with "normal" motor
Papi is offline
Old 10-24-2011, 12:01 PM
  #190
Just found on a chinese forum unpacking & assembly pictures:http://bbs.rcfans.com/forum.php?mod=...age%3D1&page=1
I put them all in my Spanish F1 blog for your comfort
http://f1rc.wordpress.com/2011/10/24...el-sakura-fgx/
prorace is offline
Old 10-24-2011, 12:42 PM
  #191
cartix's Avatar
Trader Rating: 36 (100%+)
...and I'll sell you a bridge in Brooklyn.
cartix is offline
Old 10-24-2011, 12:52 PM
  #192
Don't hate just because I was the only one to do it... It is now in the past, and I've happily moved to the FGX . That doesn't mean I won't be passing any 8scales soon. I think I'll be lapping them over and over instead....lol....
Old 10-24-2011, 01:02 PM
  #193
cartix's Avatar
Yeah right, you who gets blown away with your TC5 at Floyd Bennett.
cartix is offline
Old 10-24-2011, 01:16 PM
  #194
I never had a tc5, and FBF is in Brooklyn , thank God, not Queens ! Why not race there instead ????
Old 10-24-2011, 01:22 PM
  #195
Sorry, I forgot , no tracks there at all ....
