Like Tree164Likes
Tamiya TB Evo 6
Old 12-27-2015, 07:44 PM
  #1501
theproffesor's Avatar
Trader Rating: 66 (100%+)
I haven't run mine yet, but I did have an issue with binding when the plastic "shoe" was in the vertical position. It kept the arm from having needed up travel.
I removed about 3mm deep with of material to correct the issue. I don't think it will be a problem as I only run USGT and USVTA.
theproffesor is offline
Old 12-28-2015, 11:02 AM
  #1502
Thanks proffesor. I've just always wondered why other manufacturers haven't used swing shaft caps with their spools. I assumed the plastic cap would be a weak point
speed_dmon is offline
Old 12-29-2015, 11:51 AM
  #1503
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Just installed the Exotek conversion and I need some suggestions for gearing. I believe I will be running 64 pitch gears but if you guys have recommendations for 48 I'll take those as well. I realized that I have some spur gears that are too big to clear the top deck.
tonyv2382 is offline
Old 12-29-2015, 11:57 AM
  #1504
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
You didn't mention which wind of motor ?
For 17.5 I run 64p
73x52
3.51:1 ratio
RedBullFiXX is offline
Old 12-29-2015, 12:15 PM
  #1505
tonyv2382's Avatar
For 17.5 I run 64p
73x52
3.55:1 ratio
Yes I'm sorry 17.5
Old 12-29-2015, 02:35 PM
  #1506
For 17.5 I run 64p
73x52
3.55:1 ratio
Did you alter your internal ratio?
Old 12-29-2015, 03:50 PM
  #1507
Correction
3.51:1
Internal 2.5
Old 12-30-2015, 08:27 PM
  #1508
I'd like to see some pics of esc/motor wiring for the evo/exo's out there if possible. I'm struggling a bit with the esc orientation on my new Evo as it is a diff esc/wiring orientation from my existing one.
Looking for ideas
RollingChicane2 is offline
Old 12-30-2015, 09:32 PM
  #1509
maxepower's Avatar
Talking TB-03 Internal
76spur/53pinion = 3.495 FDR
Using TB-03 gears instead of EVO 6 gears 2.438 instead of 2.5
I would like to try 48 pitch 60/42= 3.48
17.5 R1 motor
maxepower is offline
Old 12-30-2015, 11:20 PM
  #1510
Looking for ideas
Here's my rookie setup
Old 12-31-2015, 12:25 AM
  #1511
Looking for ideas
Old 12-31-2015, 10:46 AM
  #1512
CL
CL's Avatar
Correction
3.51:1
Internal 2.5
What brand motor are you running? Is this for the TQ carpet track?
CL is offline
Old 12-31-2015, 10:59 AM
  #1513
SchuurSpeed
Yes TQ
Old 12-31-2015, 12:20 PM
  #1514
I'm encountering the same exact issue. Where are you shaving off the 3mm?
Old 01-01-2016, 05:53 AM
  #1515
vlad_sa's Avatar
Here is my freshly done Exo 6
vlad_sa is offline
