Xray XB4 thread
#9196
Super smooth, super quiet and very very durable.
I ran the upgraded graphite 4 + 2 diff gears f/r/c in my 15 and they worked flawlessly. Ninja silent, super smooth. Nice to know there standard for the 16 as they normally run $29 per diff.
#9197
Anyone using any off the following: XRAY, EXOTEK, or SPEC R aluminum shock caps on their 16? If so how is the fit/seal?
#9198
xray xb4 2016 saddle pack batteries
Hello everyone
I want to buy xray Xb4 2016 but I noticed that the vehicle can be mounted is adjusted the saddle pack batteries.
I would like to know if you can put together a saddle pack batteries and how? What should I buy?
Thanks in advance
Thanks in advance
#9201
#9203
#9204
I would like to run the stock composite rear hubs and upgrade to the Xray 12mm hex and 12mm wheels. Will the 0mm offset 12mm hex (XRA365353) and 12mm wheels (#369912 and #369913) offer the same track width as a stock 2016 XB4 setup using the kit supplied 14mm hex and 14mm wheels?
#9205
Took the time out of my day to measure the different track widths using the new Xray 12mm hex wheels with the Xray 12mm wheel hexes.
All measurement are done on the '16 XB4 using:
Width using stock 14mm wheel hexes and Xray V2 14mm wheels:
Width using 12mm wheel hexes and Xray 12mm wheels:
Front:
Rear:
Bent
- 20mm ride height (placed on Hudy 20mm droop blocks)
- 3 degree toe-in in the rear
- 1 degree toe-out in the front
- Hinge pin inserts in the middle position front and rear.
- Measured on the rear of the rear wheels (no tires)
- Measured on the front of the front wheels (no tires)
- Front: 245mm
- Rear: 245mm
Front:
- #365354 -0.75mm = 242mm
- #365353 0mm = 243,5mm
- #365355 +0.75mm (1 stripe) = 245mm
- #365356 +1.5mm (2 stripe) = 246,5mm
- #365357 +2.25mm (3 stripe) = 248mm
- #365358 +3.00mm (4 stripe) = Not enough threads on axle to secure the wheel nut.
Rear:
- #365353 0mm = 243mm
- #365356 +1.5mm (2 stripe) = 247mm
- #365357 +2.25mm (3 stripe) = 249mm
- #365358 +3.00mm (4 stripe) = 251mm
Bent
#9206
#9207
Your dedication to helping others is beyond most peoples expectation,and patience for helping is GREATLY appreciated!!!
Thanks BENTKA
Thanks BENTKA
#9208
#9209
#9210
