Like Tree1Likes
Xray T3 2012
Old 11-14-2011, 01:35 PM
  #466
jgraham37128's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Davin
Anyone know if the ECS driveshafts fit the 2012? Nexxus Racings site says they are only compatable with the T2.
Thanks in advance
davin
I moved mine from the 2011 to my 2012 and no problems.
jgraham37128 is offline
Old 11-14-2011, 01:36 PM
  #467
Any mods need to be done? And are they worth it?
No mods of any kind and yes they are worth it, it makes the car so much smoother thru the corners.
  #468
samnelso's Avatar
Might as well mention if you used 50mm or 52mm shafts as well...
samnelso is offline
Old 11-14-2011, 01:37 PM
  #469
Originally Posted by morgoth
Did they change a lot on the 2012 version? I'm thinking of buying a second hand 2011 version because a lot more cheaper for me. The 2011 T3 that I'd like to buy has a spec R gear diff in it btw.
From what I've read. The only differences are the upper and lower decks, the new servo position, servo saver, shock towers with an extra inner hole and the included hop-ups from the 2011 (Upper bulk heads, gear diff).
malkiy is offline
Old 11-14-2011, 02:00 PM
  #470
Trader Rating: 38 (95%+)
Originally Posted by M-Technic
I went from Tamiya to Xray and I'll never go back. The Xray setup window is much larger and the Xray parts quality is miles ahead of Tamiya. The T3 is so far from the T1 that you cannot even consider comparing the two.
If you want to run a ball diff they sell it, part number 305003:
http://www.teamxray.com/teamxray/pro...20T6%20-%20Set
And the battery strap kit, part number 306163-K:
http://www.teamxray.com/teamxray/pro...lack%20-%20Set
thanks for the info, now for the shocks, do i just get the aluminum xray ones, complete set or can i just order the aluminum cylinders and use the parts from the stock shocks, my question is are they interchangable, so buy part number 308306-O complete set, or will atm t2-001 just the aluminum bodies work, thanks
zaraz is offline
Old 11-14-2011, 02:10 PM
  #471
arn671's Avatar
Trader Rating: 17 (100%+)
Hey Mike, I laid the '12 chasis over the 11' before building and the cutous front and rear under the bulkheads are different. The steering link post are also a little different. It's looking like the 12' is going to be awesome on asphalt. Contemplating running the 11' top deck and barrels for steering link to stiffen it on carpet if I need to, we'll see though.
How did the build go? going to NORA this Sat.?
arn671 is offline
Old 11-14-2011, 02:54 PM
  #472
Build was easy and trouble free. There's a lot less slop in the suspension compared to my 417. Was surprising that no shimming was needed, only spacers are needed.
Yes, I plan to go to NORA this weekend Have to work Sunday though
malkiy is offline
Old 11-14-2011, 02:58 PM
  #473
You will need XRA308036 and XRA308327 to make the aluminum shock bodies work.
Might as well buy the complete shock set. Buying the individual pieces cost the same as the shock set.
malkiy is offline
Old 11-14-2011, 04:23 PM
  #474
Davin's Avatar
Trader Rating: 43 (98%+)
Are you running the 50mm or the 52mm?
Davin is offline
Old 11-14-2011, 04:33 PM
  #475
I run 52mm. I have 50mm too but I kept braking the diff outdrives. If you have any shims on the front you'll want the 52mm.
Old 11-14-2011, 04:34 PM
  #476
M-Technic's Avatar
Trader Rating: 15 (100%+)
The aluminum shock bodies are not interchangable with the parts for the plastic shocks so you have to buy the complete set.
However, it's really not necessary as the plastic shocks are very good.
Also, the ECS drive shafts work on all T2 and T3 cars as the suspension parts have not changed.
M-Technic is offline
Old 11-14-2011, 04:43 PM
  #477
Davin's Avatar
Not running any shims and Im running a spool. You wanna sell your 50s. Lol
Davin is offline
Old 11-14-2011, 04:49 PM
  #478
Company Representative
Originally Posted by locked
The local hobby stores don't cater to on-road racing. I would be shocked to see any of them with a new xray in stock. At best you might find one with a TC6.
Just order one from Canwest RC canwestrcshop.net or from another online shop.
Lou's Speedway in Dorchester (near London) stocks xray parts and he was getting a few t3'12 kits in, but I think they were all spoken for.
The only LHS that stocks a good amount on-road racing related items is muchhobby in richmond hill, but they don't stock xray.
You can check with Zoom Room Lou's or Action R/C in Kingsville.. Pinnacle will order you on as well if interested or as mentioned online with us.
Korgae is offline
Old 11-14-2011, 04:51 PM
  #479
Sure, I'll sell them I haven't used them since I went to 52mm, however it's just the shafts. I used the rest of it when I bought the 52mm.
Old 11-14-2011, 04:54 PM
  #480
Davin's Avatar
Darn I was hoping they would be complete. looks like Im stuck ordering new. but Im now torn between 50 and 52
Davin is offline
