Xray T3 2012
#496
Anyone have a good recommendation on where to start for a gear ratio. 17.5 stock No Boost? Ive been running boost for years but rules just changed to blinky only. (Due to the recommendation of some guy who doesn't even race at our track mind you) So now I have to start over looking for that sweet spot again.
#505
Trader Rating: 101 (100%+)
I've been using 100 spur with a 50 pinion. 1 dot on the X12 17.5
temps at 140-150.
final 3.8, has been trouble free
#506
Did anyone drill a hole in the shock caps? Or just left them alone.
#509
Is the CVD shaft hitting the outdrive cup, or is it binding before that point?
When I built my T3'11 I noticed the camber link settings shown in the manual were a bit on the short side, giving me around 3.5 degrees of camber, and there was some binding, backing the camber off to 2.5 or so freed everything up happily.
