Tamiya mini cooper
#4426
TA-03 DIFF
Okay, i see now - thanks.
#4427
Ran my M03-M Swift for the first time last night. I'm running the black tin Tamiya Sports motor and TA03 ball diff in it and had a great time. The car has a bit of bump steer, which I'll fix with a different servo horn. Loved the way the car went, drove it like how I drive my 415, and seem to go pretty well, but you have to be really sensitive with throttle movement in corners. With mine the rear end will step out if you get off the throttle too quickly. Plus need to shoe-goo my screw in the diff, damn thing kept coming loose.
Great little car, can't wait to race it more.
#4431
Mine has only ever stepped out if I have the wrong tires on the car. Otherwise if anything the car pushes a little off power and just pulls through the corner on power. No sign of stepping out.
#4437
When your assembling the stock gear diff...the shims you use next to the output bevel gears as your assembling it. I personally use 2 on each side instead of the 1 described in the instructions. Here is a pic of the parts. The washer looking pieces are the shims.
#4438
new parts
