Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 12-12-2005, 08:19 AM
  #2101
rc-zombies's Avatar
my Purple Version arrived last week...
Attached Thumbnails Hot Bodies Cyclone-rear-l-purple-cyclone-001.jpg   Hot Bodies Cyclone-rear-l2-purple-cyclone-003.jpg   Hot Bodies Cyclone-front-l-purple-cyclone-002.jpg   Hot Bodies Cyclone-left-side-purple-cyclone-004.jpg   Hot Bodies Cyclone-purple-right-cyclone-005.jpg
rc-zombies is offline
Old 12-12-2005, 09:05 AM
  #2102
rc-zombies's Avatar
[QUOTE=John Doucakis][url]
6. Updated Middle Block R included
.QUOTE]
might look like this:
Old 12-12-2005, 09:14 AM
  #2103
Skill's Avatar
Isn't that a similar design to the original? There must have been a reason for changing to the curved piece, I wonder why they've gone back to the straight bit?
Skill is offline
Old 12-12-2005, 09:17 AM
  #2104
rc-zombies's Avatar
the part I posted will be made by Square RC and released today. available in purple or black. not sure what the revised part will look like... just taking a guess at it..
Old 12-12-2005, 09:36 AM
  #2105
Buyer Beware
very nice....mine is the black out version...kitty
HELLOkitty is offline
Old 12-12-2005, 12:01 PM
  #2106
ngo8's Avatar
Originally Posted by Hollowman
New Version My Ass (one really pissed out dude over here)
come on people the version isn't that exciting, just look at the hop - ups only Nr. 6 & 12 are interesting and i think that 6 is the shooters motor mount brace but i don't know.
and we don't race spools in Holland so waste of money and come on alu servo mounts that's 15 euro's about 20 dollars, and thicker shock towers Why ?? but i am curious about the blue version it will be one hell of a MSX wannabee. i want to see a battery bar and the multi-flex system i want it to compete against the new x-ray .
But if i don't like the black any more i am gonna make my one Florian Spec cyclone that will be all green with a hint al purple titanium (just my dream )
Greetings Florian
heheeheh you should make a dutch orange like the soccer team hehhehe i dont think these are new version just what people are asking for purple versions.
ngo8 is offline
Old 12-13-2005, 03:14 AM
  #2107
EvilDriver's Avatar
Originally Posted by John Doucakis
Some pics of my Cyclone.
I think they fit nicely as a wallpaper too in case you like them.
Looks nice john.. Always nice to see that car of your's.
EvilDriver is offline
Old 12-13-2005, 03:56 AM
  #2108
The Teacher's Avatar
Trader Rating: 62 (100%+)
Need some help??? I just put my Cyclone on order through my LHS and I need to find out what parts I need to get to build a front diff. I know you guys have figured it out and have probably posted it but if you could tell me again this would be a big help.... Thanks!!!
The Teacher is offline
Old 12-13-2005, 03:58 AM
  #2109
Hollowman's Avatar
Yeah that's a great idea only one problem i am not a soccer fan but i don't care i like the color orange anyway i just might do that make it a Team Orange Spec Cyclone and then with the red white and bleu shell ,
That updated middle block looks very familiar to the MSX .
And Rc - Zombies i am not really feeling the color it is not the hpi violet purple, i personally don't like it.
Greetings Florian
Hollowman is offline
Old 12-13-2005, 08:16 AM
  #2110
rc-zombies's Avatar
.....And Rc - Zombies i am not really feeling the color it is not the hpi violet purple, i personally don't like it.
Greetings Florian
just bad lighting...the re-colored purple parts matches the HPI Purple.
Old 12-13-2005, 10:28 AM
  #2111
wyd
wyd's Avatar
Trader Rating: 51 (100%+)
My hero!!!!!!!!!!!!!! These are nice looking cars. Not waiting on the EC?
wyd is offline
Old 12-13-2005, 11:14 AM
  #2112
The stock piece bends if you have a very hard frontal crash. This permanently tweaks the car until it is replaced. HB didn't figure this out until regular joes started beating on the car.
Carbuncle is offline
Old 12-13-2005, 03:53 PM
  #2113
danjoy25's Avatar
Trader Rating: 38 (100%+)
Can someone be kind enough to post the part # needed to make another rear diff?
danjoy25 is offline
Old 12-13-2005, 04:49 PM
  #2114
Bob-Stormer's Avatar
I believe this is the information you need.
HPI Parts
A150 Thrust Balls 2mm
A157 Carbide Diff Balls (3/32) 2.4mm
A165 Diff Spring 6x7x1.5mm Black
A166 Diff Thrust Washer 2.2x6mm
A495 39t Ball Diff Pulley
B020 Ball Bearing 5x8x2.5mm
Z203 Washer M3x6
Z857 Aluminum Washer 5x8x1mm
72105 Diff Ring D Cut Type
73522 Diff Screw And Heavy Duty Nut
Hot Bodies Parts
HB70715 Diff Cup Joint Set
Bob-Stormer is offline
Old 12-13-2005, 04:54 PM
  #2115
ngo8's Avatar
ok here you go
73522-----diff nut m2x6mm
70725-----center pulley(16t)this pulley is for replacing the center one way
72105------diff ring d-cut type
A-495------39t ball differential pulley
Z857--------alluminum spacer 5x81.0mm you dont have to use this use 2 bearings instead
70715a-70715b dif cup joint set
A-165-diff spring
A-162diff screw
hpi/hotbodies b021 5x8x2.5mm bearing use 2
A-150 diff ball 2.0mm for thrust bearing
A-157 diff ball 2.4mm
A-166 diff thrust washer
i think this is it let me know how it goes .
ngo8 is offline
