NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 09-23-2011, 06:40 PM
  #6406
COBRARACING's Avatar
Be aware that Ebay store wasp2018 is 100% counterfeit/fake hobbywing products.
I will get around to completing my list .
COBRARACING is offline
Old 09-23-2011, 08:43 PM
  #6407
Hi Guys
Just some news out of china this morning there was a raid at a factory in shenzhen by 15 government officials and police were 20 people were arrested including the owner of the factory .
The factory was full of hobbywing copied products in production and ready to leave for the market .The arrested are facing of 3-5 years in prison .so as you can see we are very serious about this issue.
will keep you all informed .
regards Angelo
Old 09-23-2011, 09:57 PM
  #6408
Originally Posted by COBRARACING
thank you go it .
Hi Angelo, I sent you a PM about 2-3 days back requesting the files to try out the 213 software.
Still waiting for a reply.
SeanV is offline
Old 09-23-2011, 10:03 PM
  #6409
bkspeedo's Avatar
no it's not an issue with the esc or the motors the problem lies in the software were we have a very high sensitivity sensing for the sensor port of the esc and because of the very high currents in low turn motors and the turbo functions that give us enormous power as well as high end bell adjustment the signal from the motor to the esc is distorted in some way or the other thus the esc cannot process a clean signal and sending the esc to sensorless mode as it has detected a low signal from the motor because of the high currents so we are in the process of producing a lower sensitivity sensing in the software ill keep you informed .
regards Angelo
It's funny the Hobbywing folks found this to be a problem and not Speed Passion. I posted about this same issue on the SP thread several months ago. This issue occurred with my SP v2 and 2 motors, X12 & MurffDog. They said it was the sensor boards in the motors. The motors work fine with a Tekin. So i knew it was not the motors but the ESC.
Good job Hobbywing finding a solution to this issue. Just bought a ExRun 1s looking forward to giving it a try.
bkspeedo is offline
Old 09-23-2011, 11:54 PM
  #6410
PizzaDude's Avatar
Hi Guys
regards Angelo
Great job
Congratz angelo,
PizzaDude is offline
Old 09-24-2011, 12:17 AM
  #6411
Thank you for your kind words.we are here for people like you the customer so we try everyday to improve our software and the product the ones who deny there is an issue with there products and do nothing about it are only delaying the inevatable and thats the customer going elsewhere .
thank you once again.
Old 09-24-2011, 12:19 AM
  #6412
Sean im waiting on michael to send the control files and ini files to me as the 213 was only a proto and was never going to be released it was actually designed on the run at the titc thailand .
Give me until monday night and i will send the files to you .
Old 09-24-2011, 01:32 AM
  #6413
Just got the xtreme stock and looking for a starting point setup. Will be running touring, 13.5t HPI flux pro,high grip Carpet, tight but with 25-30m straight. Very heavy handed on the throttle.
As a safe starting point i was going to run
FDR 6.95
boost timing 36
turbo open 6/0.1
over heat on
turbo 24
boost start 9000rpm
Delay 0.3
boost acc 450
Anything anyone would suggest different and what should i be looking to change first or setup in what order?
Any help or suggestions appreciated.
YZFAndy is offline
Old 09-24-2011, 01:42 AM
  #6414
defcone's Avatar
Trader Rating: 15 (100%+)
FDR 6.95
boost timing 36
turbo open 6/0.1
over heat on
turbo 24
boost start 9000rpm
Delay 0.3
boost acc 450
I tried the 17.5t dualsky, and I could only get it to be within 75 deg. by turning the timing on the can down to 9-11 deg.
defcone is offline
Old 09-24-2011, 02:28 AM
  #6415
Hi Guys
Just making you aware of our Battery brand .I have attached two photo's for you to view .
Is there a UK supplier for these?
scoop is offline
Old 09-24-2011, 02:47 AM
  #6416
And what is wrong with 75 deg? this is fairly normal heat for a motor.
If you put more of your setup, fdr etc... we can guide you better
olly986 is offline
Old 09-24-2011, 02:51 AM
  #6417
FDR 6.95 not sure, you can probably reduce to 6.50
boost timing 36
turbo open 6/0.1 change to 12/0.1s
over heat on
turbo 24
boost start 9000rpm depending on your track this is a lot, try 4/5k
Delay 0.3
boost acc 450
this is what I would suggest to try
olly986 is offline
Old 09-24-2011, 03:53 AM
  #6418
J SiN's Avatar
I seem to be having a issue with my Xtremestock ESC, every time I try to run 5000 turbo timing it doesn't seem to kick in at all and will run very slowly. I have tried different boost settings as well which don't seem to help the issue I can go to 6000 and it will work and 4000 works fine.
I have also had this issue with 3 motors 2 sensor cables so I don't think its them.
Any help would be great
J SiN is offline
Old 09-24-2011, 04:25 AM
  #6419
Just tested it and it worked with mine will flash twice per second .Do a calibration of your radio forward,neutral ,reverse and you will see it will be fine .
I looked closer and it does blink but it is very faint. As a suggestion, improve the red led brightness to be similar to the green and slow down the blink, it will be easier to see.
Reds and oranges are the most common colors that color sensitive eyes don't see.
Thanks for the answer.
Is the new software going to address the cutoff voltage issue in the 1S?
old_dude is offline
Old 09-24-2011, 05:23 AM
  #6420
it seems you have a corrupt file in your software thats skips the 5000rpm start i dont know how but thats what it seems to me .
Please reload the software to your esc via your pc .If that doesnt work please send me an email at [email protected] and i will email you back software to sort it out for you its actually a procedure .
regards Angelo
