#9332
if its correct you were also running the 4.5T thunderpower with boost 30 and turbo 30 deg. is this correct?
i started with boost 6 and turbo 20-30 which already produced a hot motor (80-90°). endbell timing on motor 10°
#9333
Here is the settings of Andy Moore using on ETS Gran Canaria.
Reedy 4.5 8.0 FDR, 5th mark on endbell.
Section Item Programmable Items Modify 4.5T
General Setting 1A Running Mode Running Mode For/Brake
1B Reverse Speed Reverse Speed 25%
1C Voltage Cutoff Voltage Cutoff 6.0
1D ESC Overheat Protection ESC Overheat 125 ℃
1E Motor Overheat Protection Motor Overheat 125 ℃
Throttle Control 2A Punch Rate Control Punch Rate Switch Point PR SW Point 50%
2B 1st Stage Punch Rate 1st Punch Rate 15
2C 2nd Stage Punch Rate 2nd Punch Rate 15
2D Throttle Input Curve TH Curve linear
Brake Control 3A Drag Brake Drag Brake 10%
3B Brake Strength Brake Strength 75%
3C Initial Brake Initial Brake =drag brake
3D Brake Rate Control Brake Rate Switch Point BR SW Point 50%
3E 1st Stage Brake Rate 1st Brake Rate 20
3F 2nd Stage Brake Rate 2nd Brake Rate 20
3G Brake Input Curve Brake Curve linear
Timing 4A Boost Boost Timing Boost Timing 8 Deg
4B Boost Start RPM
BT Start RPM 14000
4C Boost End RPM BT End RPM 26500
4D Boost Slope BT Slope Linear
4E Boost Controlled by Throttle BT By TH Yes
5A Turbo Turbo Timing Turbo Timing 20Deg
5B Turbo Activation Method TT Activation Full TH
5C Full Throttle Delay (sec.) Full TH Delay 0.2
5D Turbo Start RPM TT Start RPM 40000
5E Turbo Engage slope (deg/0.1sec)
TT Eng Slope 21
5F Turbo Disengage slope (deg/0.1sec)
TT DEng Slope 18
4B Boost Start RPM
BT Start RPM 14000
TT Eng Slope 21
TT DEng Slope 18
#9334
For the V3 speedo user, we suggest you to try FIRMWARE 0511_BETA, it is faster than the previous version. And the punch for the low end is better.
#9335
4B Boost Start RPM
BT Start RPM 14000
TT Eng Slope 21
TT DEng Slope 18
4B Boost Start RPM
BT Start RPM 14000
TT Eng Slope 21
TT DEng Slope 18
#9336
#9338
on another topic. i looked up one of your speedo setups in this thread for the v3.
Now i will put on a fan, to get the motor a bit cooler. I don't think the temps are too much of a problem, i have read that the ThunderPower motors can cope with more if needed.
How much do you use full throttle? I only used it on the straight, as the turbo gives to much power to use in the infield.
#9339
cause the speedo support 3S LIPO, the normal high voltage is around 12V, so the software set the default value to 12V, and record the lowest voltage if captured by the program.
If you disable the voltage cutoff function, it will show12V.
#9341
i ran 511 beta on sunday and it was great !
did notice the 12v in the data logger, will activate the low voltage cut off and see if it reads correct after that
#9342
Logging
Is anyone having trouble with the logging function? My Esc temp reads ok, Motor temp I use ThunderPower motors so not sure if these will work for this function but it reads 0 after a run, Min battery voltage is always 12.6v and my motor RPM is reading 68,000rmp...on a 10.5 motor ????
I am switching it off by the button after a run, plugging in program box, switch ESC back on again and taking reading then, I think this is correct..
Thanks,
Keith
Thanks,
Keith
#9343
Hi guys, I know a lot of you have moved on to the new v3. But can some one clear this up for me about the old xerun 120A? I am thinking of buying a hobbywing xerun 120A (the old version) and I am looking at this combo here. It's a xerun 120A + program box + 4.5T motor.
http://www.hobbypartz.com/07e-4-5t-3...-120a-lcd.html
In the description, it says the xerun 120A is a version 2.0 and not a 2.1. What is the difference? Is that just a firmware difference? or is there something else?
I am new to hobbywing esc and have heard good things about it. I know some of you guys are going to tell me to get a v3 instead. But I found it a bit too expansive at the moment. And I trusted that the old xerun 120A is still a solid performer. So I would really appreciate it if someone can clear this version 2.0 and 2.1 issue for me.
If the deal really comes with a v2.0, would I be missing out a lot of the programming functionality? Should there be anything I need to worry about? I really don't mind getting something older for a cheaper price. I just want to know what I am missing out on.
#9344
Thanks,
Keith
Thanks,
Keith
