Diggity Designs Custom R/C Components
#541
i wish we had a track like that, digs. maybe we could convince roy at RR to put a big slab of asphalt on the flat peice of land behind the pit spaces... I still want to run some asphalt... Wow is all i can say to that picture.
Max K
Max K
#542
too bad you guys dont live closer because you could come down for our Sedan Challenge in 4 weeks we are expecting a ton of racers for touring stock and 19t along with stock 12th of course, oh and I believe there will be a mini cooper class as well.
#543
#544
Originally Posted by KHoff7
Jason
#546
Originally Posted by WillS
Hey diggity, how did you come up with the lightened polished outdrives? Im realizing polished is the way to go instead of anodizing everything at the moment.
#549
Well I took the Diggity out for its first run today, I went off my base setup and I didnt have to change a thing the car was amazing my lap times went from mid to high 13's to low to high 12's, the car never pushed and the back end never came out on me, as for durability it was great my rear end got smacked by a sedan goin fast and the car didnt tweak at all and I kept runnin, if that had happened with my crc it would have tweaked bad, you nailed it on the rear pivot design it is durable without play or binding.
CD12
CD12
#550
CD12
CD12
Excellent showing... Great words and telling it just how it is!! Keep up the rip..
Digs
#551
Diggs, you got e-mail.
#552
Karl,
whats your setup on your CD12... I'm gonna run some asphalt this weekend!!!!!! FINIALLY!
Max K
Max K
#553
The setup is,
white side springs
7k in tubes
30wt oil
AE silver shock spring
grey rear procuts
purple front procuts
about 3mm ride height rear
about 3.5 mm ride height front
white side springs
7k in tubes
30wt oil
grey rear procuts
#554
HOT DIGGITY !
See you the 23rd Karl !
Digs I sent u email bout tires !
#555
Well I took the Diggity out for some more practice, the car just gets better and better. My lap times are getting lower and staying consistent the car did not tweak ONCE at all after many hits fron tourers around the track I didnt change anything on the setup because the car felt so good, now all I gotta work on is my drivin
