TLR 22 3.0 Race Kit Thread! >
Like Tree26Likes
    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Old 10-20-2016, 05:30 PM
  #3661
Team Pink's Avatar
Trader Rating: 20 (100%+)
Originally Posted by SickNT760
Thank you for the response, I did end up switching them for now. The washer is still needed correct? I will order some of the Ti ball studs as well. One last thing on this, what is the preferred hole placement on the hub? Track is med/high bite clay.
NP. Yes the shim on the hub is still there. The preferred hole on the hub is back row, middle hole. Also remember that on the 3.0 these hubs should be reversed (L on R) and (R on L). The hubs were originally designed for the 22-4.
Team Pink is offline
Old 10-20-2016, 06:20 PM
  #3662
Oh wow I did not even know about swapping the hubs around thanks again for the info.
SickNT760 is offline
Old 10-20-2016, 11:53 PM
  #3663
tommynash's Avatar
Neither did I... whoops
tommynash is offline
Old 10-21-2016, 04:00 AM
  #3664
I Just looked at which way the ball stud holes in the hub matched the holes used in the plastic hubs. Of course there are two more holes on the inside, but I suppose I've got them on correctly.
Callaway is offline
Old 10-22-2016, 11:59 AM
  #3665
tommynash's Avatar
So you didn't switch them?
Old 10-22-2016, 05:12 PM
  #3666
Has anyone tried a set of these in their 22 or any other vehicle? Or similar slipper pads....
https://www.amainhobbies.com/mckune-...r10034/p500989
Medicinal Coma is offline
Old 10-22-2016, 07:32 PM
  #3667
I don't see them marked R or L, but it matches the assembly drawing that came with the laydown kit.
Callaway is offline
Old 10-22-2016, 08:55 PM
  #3668
tsair's Avatar
I use the RC Shox version (Garodisc) in my 22T 2.0. IMO they are more consistent and engage more smoothly than the TLR pads. Here's my review:
http://razorrc.tumblr.com/post/14469...er-pads-review
tsair is offline
Old 10-23-2016, 11:27 AM
  #3669
motorcitymatt's Avatar
I'm thinking of picking up a pair of the Universal driveshafts (TLR232006) for use on a high-bite indoor astroturf track. These are labeled 66mm. Given the CVD shafts on the 22 3.0 have been changed to 67mm, will I be able to run these without a spacer/shim? Maybe the geometry is different? Does anyone have some experience with running these on the 3.0?
motorcitymatt is offline
Old 10-23-2016, 01:42 PM
  #3670
Team Pink's Avatar
You should have no problems running them. Just use the axle shim.
Old 10-23-2016, 04:00 PM
  #3671
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
They should work great on that surface. Just use the 1mm axle shim, and you're good to go!
Frank Root is offline
Old 10-23-2016, 06:14 PM
  #3672
Trader Rating: 33 (97%+)
pretty good article here worth a read to get a better understanding of selecting the right length drive shaft for your track conditions:
http://site.petitrc.com/setup/losi/s...llCenterShims/
Originally Posted by TLR
More dogbone plunge creates more mechanical bind and gives the car more grip.
I started out with the stock 66mm shafts and no axle spacer, and the rear end would get a little twitchy on me from time to time when the track (dirt glue spray) got a little dusty toward the end of a race day with too much foot traffic (especially with a large novice turnout and lots of kids running all over the track), I later switched to 67mm shafts with the 1mm spacer and now I manage to get far more consistent traction, sometimes my car will still be hooked up on rails when most others are spinning out of control on corner exit.
billdelong is offline
Old 10-24-2016, 12:40 AM
  #3673
thecman26's Avatar
Trader Rating: 112 (100%+)
oops
thecman26 is offline
Old 10-24-2016, 11:54 AM
  #3674
GasserX's Avatar
whats the best way to reduce dirt laydown transmission noise? I have used the black grease on the gears and it didn't help much. Is my case screwed together too tight?
GasserX is offline
Old 10-24-2016, 03:16 PM
  #3675
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i dont know, i have tried black greas, white lithium grease....tight screws, loose screws, i have marked the bearing holes to make tighter fitting bearings.....nothing....it sounds like a 4x4 sct....it is loud....
Matt M. is offline
