Durango DEX210 Thread
#7786
HELP!
Hey guys at the moment I am leaning towards the tlr cars, but they don't have a 4wd, are a little more expensive, but my lhs has them. However I found a place a little ways away that carries Durangos. I can't decide so I need you to convince me to buy Durango! I am putting an equivalent post in TLR page so do your best! Thanks for the help!
Zeus
Zeus
#7787
Zeus
Zeus
#7788
#7790
Just in case you guys didn't know...Hobbypartz now has Gens Ace shorty lipos in stock.
$50 shipped http://www.hobbypartz.com/98p-60c-42...se-shorty.html
#7791
fellow dex210 racers i just received a dex210 with gear diff shocking i rather have had a ball diff but any insight on diff oil to use and anyone have a ball diff for sale or just rock the gear diff????
#7793
Hey Guy, I recently got a DEX210 and im in love. I don't own a TLR 22 so i can not compare but i can tell you that the DEX210 is nice. Material quality is great, shocks are super nice (some of the nicest i have ever used). The oil diff is easy to build and mine has never leaked, after many ball diffs I was happy to go back to an oil diff in all honesty. The chassis tub has plenty of space so fitting your electronics is easy. The amount of tunablity is mind boggling but the box setup has been working well for me so far. I race on indoor clay with medium grip using an 8.5 turn motor. Parts are easy to get for me, but i'm not sure about your area, always good to check. In all honesty parts availability can make or break your experience with a car. If you choose to go with a DEX210 you will not be disappointed.
#7794
#7795
Hey I just switched mine to mid motor for indoor carpet, what the heck side do I run the motor on???? I see pics with both sides, right now I have it set with the spur pinion on the left, is that wrong?
#7796
If you're running the spur on the left, it means the box is in 4-gear configuration Which is the normal way to run a mid motor. Most important when running mid is to use 0 or 1.5 antisquat not the 3 degree block.
#7797
I'm confused, it is 3 gear, I just flipped the plate to the other side when I switched it from rear motor. Should I flip it back? Is it evident yet I have no idea what I'm doing? I don't have a manual so I just put it together how it made sense from pictures that I have seen.
#7798
I've been using the RC Shox rear camber mount replacement part but am looking at trying another brand. Other than Tresrey's piece, anyone know of another one they like that I may want to try? Thanks for any suggestions.
#7799
The Durango motor guide may be of interest to you: http://www.team-durango.com/blog/201...onfigurations/
