MRX-4X
Old 09-24-2009, 01:52 PM
  #1201
of course it depends on the track ..... What track to you normally run ?
I'd like to see how much different you are running then the stock set up
You stay on Marco !! Nice place huh?? Intoduce yourself this year, I should be behind the Tech table with Julian.
CFowler is offline
Old 09-25-2009, 05:40 AM
  #1202
MugenDrew's Avatar
Trader Rating: 36 (100%+)
16-49 everywhere
19-47-46 at the fort
20-47 at Kraceway last club race. Did not like it because it loaded the engine to much in the big in field s at throttle clamped. I'll try a 19-45,46 next time.
MugenDrew is offline
Old 09-25-2009, 12:31 PM
  #1203
What sizes on the tires do you use there??
CFowler is offline
Old 09-25-2009, 01:15 PM
  #1204
MugenDrew's Avatar
Start saturday morning @ 76/69. Do the open practice thing and rotate left to right each tank. Qualifing 74.5/67.5. After each qualifier I'll rotate the rears and cut the fronts to keep the split. 73.5-72.5 rears are money.
This is of course when I'm racin lol call jim then call me...get it
Old 09-29-2009, 06:23 PM
  #1205
CanyonCarverR1's Avatar
Trader Rating: 13 (100%+)
Default Collapsed shock bladders
I have a question about my shock bladders. Every time I take the shocks apart to service, the bladders are partially collapsed. Anybody else seeing this? Just doesn't seem right.
CanyonCarverR1 is offline
Old 09-29-2009, 06:48 PM
  #1206
wingracer's Avatar
Trader Rating: 24 (100%+)
They will do that. Because the cap is 2 pieces they are not air tight above the bladder so it will partially collapse before long.
wingracer is offline
Old 09-29-2009, 10:08 PM
  #1207
asw7576's Avatar
I use japanese rc accessories name : Pit Shimizu..... Pit Shimizu sell flat surface silicone bladder ( light pink or light blue silicone rubber ) and with black foam insert. They perfectly fit into mugen seiki damper. No more collapsing bladder problem with flat surface bladder...... btw, I dont recall my car handling differences between concave bladder vs flat bladder.
asw7576 is offline
Old 09-30-2009, 05:53 AM
  #1208
MugenDrew's Avatar
Per the manual when you put the shock cap on the piston should be all the way at the top of the shock body. I push it up until the nut is just under the surface of the oil. Screw the cap on like one turn then angle the shock so that the bleed hole is up and slowly screw the shock into the cap. The bladder will push the shock piston down as you screw it together. No more cut or collapsed bladders.
When this was first pointed out to me I worried about rebound and all that other fun stuff but it works and thats the way Mugen wanted it.
It's interesting to look at the manuals for there other cars because there shocks are all set up different and Mugen is very specific about the position of the piston when the cap gets installed.
Old 09-30-2009, 06:55 AM
  #1209
Trader Rating: 18 (100%+)
Default Mugen
It's interesting to look at the manuals for there other cars because there shocks are all set up different and Mugen is very specific about how the cap gets put on.
Thats a great tip. I did not see that one. I always wind up checking and refilling the shocks after one ray of running due to collapsed bladders
brc358 is offline
Old 10-02-2009, 05:37 AM
  #1210
Default Mugen MRX4 Rubber Tyres/Not Foam
Is it possible to find rubber tyres, not foam for the Mugen MRX4???
thnx
waelzoghbi is offline
Old 10-02-2009, 06:05 AM
  #1211
The tires which come with the Edam Spirit 1/8 RTR are rubber tires but on Serpent rim.
Roelof is offline
Old 10-08-2009, 07:45 AM
  #1212
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
BUILT UP X 4 SALE, GOING TO 4 SALE HREADS!
TommyBlazin is offline
Old 10-08-2009, 08:57 AM
  #1213
Kodak Hodak's Avatar
Guys any news on the new MRX5? - whats the rumour of new kit for 2010?
Kodak Hodak is offline
Old 10-10-2009, 07:18 AM
  #1214
mugenize1's Avatar
Any body know of a Good starter box for the mugen. What would be the best box to start the cars. (MRX4X)
mugenize1 is offline
Old 10-10-2009, 07:23 AM
  #1215
Team Kamikaze's Avatar
This is the best starter box for your MRX 4X. here: http://kamikazetoysandhobbies.com/pr...?prod=MUGB0220
Team Kamikaze is offline
