1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2919Likes
Old 08-16-2013, 12:24 AM
  #9241
DIRTMONKEY's Avatar
Originally Posted by Ph3nyx
Sadly i'm painting a new mercedes 2013 with the f2012 body ... the difference is that so big with the f60?
what do you use to paint the wings ?
I found that using FASCOLOR paints letting dry over night then spray an automotive clear coat and dry that with a hair dryer, did this to my FGX wing for the LOTUS 2013 no cracks no peeling didn't even show signs of fractured paint after siding on the wing in accidents.
leave any masking on until complete dont spray the clear coat directly on the plastic.
Attached Thumbnails 1/10 R/C F1's...Pics, Discussions, Whatever...-553055_635703186443769_678878528_n.jpg   1/10 R/C F1's...Pics, Discussions, Whatever...-p1010007.jpg
DIRTMONKEY is offline
Old 08-16-2013, 02:53 AM
  #9242
Ph3nyx's Avatar
You don't use sand paper first ?
Ph3nyx is offline
Old 08-16-2013, 01:33 PM
  #9243
DIRTMONKEY's Avatar
NO just clean with metho let dry, If you use sand paper or even a scotch bright pad it will show in the paint The key is to let dry completely. I have used mine in four rounds so far and still looks new and so does my team mates
Old 08-16-2013, 07:19 PM
  #9244
Ph3nyx's Avatar
ok thanks, i'll try it on a future project.
Ph3nyx is offline
Old 08-17-2013, 08:24 AM
  #9245
Thunderbunny's Avatar
Trader Rating: 27 (100%+)
Originally Posted by merkyworks
I thought it was just the F2012 front wing that messed things up and by putting a F60 front wing on fixed this.
IMO, using the F60 front wing on the F2012 looks bad. The scale appearance is very important to me so I just defer to the F60. The F2012 does look sexi though
Thunderbunny is offline
Old 08-19-2013, 03:44 AM
  #9246
wtcc's Avatar
I had my first two races on saturday with the front axle. It is impressing how much more speed the car carries through a corner and how fast in turns in the middle of it.
Even with only 80% motor power (otherwise I won't be able to get over the 15 minutes with my 10.5t) I could lap 15.4s (before with full power 15.9s). The second race was the most fun as I could battle with the Pro10 drivers. It was thrilling not to make any mistake as the field stayed close together all the time.
wtcc is offline
Old 08-19-2013, 08:06 AM
  #9247
b-man777's Avatar
Hey all: Didn't know where else to put this so I thought i'd ask here. Love the look of the new Corally USA site and was wondering if they had plans on a slx version of there F1 and WGT pan cars? Thanks
b-man777 is offline
Old 08-19-2013, 12:36 PM
  #9248
Cancun Tom's Avatar
Default Chassis?
WTCC,
What chassis are you using in the Ferrari?
Cancun Tom is offline
Old 08-19-2013, 01:36 PM
  #9249
wtcc's Avatar
Originally Posted by Cancun Tom
WTCC,
Except for the front axle everything else is a F104v2 pro.
wtcc is offline
Old 08-19-2013, 04:40 PM
  #9250
Any tips on how the paint the driver ad with what?
d.k.vmatt is offline
Old 08-19-2013, 05:13 PM
  #9251
Professor's Avatar
Trader Rating: 12 (100%+)
so which front end set up is that ?? looks lik the t.o.p. front end
Professor is offline
Old 08-19-2013, 06:23 PM
  #9252
malcnz's Avatar
the goodyear tyres stickers really finish it off
Attached Thumbnails 1/10 R/C F1's...Pics, Discussions, Whatever...-dscf1669.jpg
malcnz is offline
Old 08-19-2013, 06:36 PM
  #9253
It's Associated TC6 parts, go back a few pages in this thread to see where it came from.
http://www.rctech.net/forum/12412862-post9176.html
http://www.rctech.net/forum/12439897-post9223.html
terry.sc is offline
Old 08-20-2013, 02:11 AM
  #9254
Hi guys, Me again with a quick question - Can anyone tell me why you should drill holes in the wheels when putting the Pit Shimzu tyres on?
Is it as obvious as helping heat dissipation, or are there other reasons?
Cheers!
simmo0916 is offline
Old 08-20-2013, 02:58 AM
  #9255
malcnz's Avatar
Cheers!
all rubber tyres need a hole drilled in the inside of rim(to let air escape from heat build up i think) and if you are using foam rims for rubber they wont have a hole std.
malcnz is offline
