VBC new 1/10 touring car, Wildfire.
#916
I'll be running VTA. I'm not concerned with the ratio, I'll be running 78/35 for a 4.2 FDR. I just want to know that it will fit on the car properly cause I can't find a VBC 78t 48p spur. So basically, will this spur mount on the wildfire;
http://www.amainhobbies.com/product_...pur-Gear-H-78T
#917
Hey Chrisg23, I'm guessing your running the 21.5 at trains and lanes. If you look at something like 104t spur and 47 pinion puts you much closer to that 4.20 ratio
#918
#919
Chris you have more options with 64 pitch gears.
#920
#922
#924
After getting out my pocket protecter and doing some math, your advice is dead on. 104s/47p x 1.9 = a 4.204 FDR. Thanks for the info.
#925
My shopping cart has been edited!
#926
Does anyone know what weight the diff fluid is that comes in the kit?? Also are there any plans or is any company making aluminum spool outdrives??
#928
Hopfully someone from crc can chime in and let us know.
#929
#930
Not really. I just changed the roll centers, oils (Losi 40/35), rear diff and am not running raked as far as ride height.
I've only driven the car for ten minutes (Racing), so I didn't want to get too crazy with setup changes.
As it is, the car is very fast... I tied fast lap of the day (To the thousandth, 14.465)
