VBC new 1/10 touring car, Wildfire.
#1066
6.75mm an xray blade fits these.
#1067
I think that you should try to get A-Main Hobbies to carry all of your VBC parts. They have most of them, but not all of them are available. Most RC hobbyists know and shop with A-Main Hobbies, plus it is extremely easy to locate and order whatever you want, with or without part numbers.
#1069
#1070
VBC Wildfire D06
The WildFireD06 is an all new platform, designed to increase traction, improve flex points, improve weight distribution, and center of gravity.
1. All-new motor mount design, moving the motor more centerline and forward increasing corner speed and overall agility of the car. Making this the most centerline touring car on the market.
2. All-new motor mount can incorporate a wider range of gear ratios from 21.5 up to modified classes
3. All-new chassis and upper deck providing more linear flex response and better weight balance
4. All-new redesigned front and rear A-arms to be much stronger but still lightweight
5. All-new roll bar mount for smoother response and easier adjustments
6. All-new 4mm thick lowered graphite shock towers improving CG
7. All-newly designed 'True Big Bore' shocks (TBB). Shorter shock shafts, bigger shock body diameter keeping the volume the same as original shocks
8. All-new TBB springs with 4 different rates
9. All-new redesigned lower bulkheads which are lighter in weight and stronger in durability by using our new manufacturing process
10. All-new upper camber link position for more linear cornering response
11. All new 7075 aluminium ball connectors
12. Front 2-piece joint drive axles included
13. All-new lightweight 7075 aluminium centerline servo mount included
14. High quality Panaracer 116T spur gear included
**Pre-production Photos
#1072
This latest evolution is probably worthy of its own thread.
#1074
i will post setup later on guys or PM me
#1075
The new VBC Wildfire D06 is really awesome!! I've only ran it twice and been super happy, once on asphalt and once on carpet. The whole team has tested this car immensely, and I can assure you won't be disappointed!
Here are my setups with the new car. They can be applied to the old car too i'm sure!
If anyone has any questions, please feel free to PM me or ask on here, and myself and any of the other team drivers will be able to help you out!
https://www.dropbox.com/s/tkj26m71xt...er_Testing.pdf
https://www.dropbox.com/s/xqb7d3twcg...AOCRd22013.pdf
Best Regards,
Ryan.
Best Regards,
Ryan.
#1076
1. My name is Victor, part owner of VBC. If any of the distributor doesn't answer your questions, I will. If you have any questions, you can directly send emails to my address [email protected]
2. What should we improve on our website? I am here to listen for your valuable comments
3. We feel that it is time to introduce our new product due to the last WildFire is begin to outdate.
4. New photos will be posting up as we are peeping photo shoot next week.
I really regret to hear all your unhappy comments on VBC but I hope that I can solve some of your problems.
BTW, VBC stands for Victor Bernard Company. No other special meaning.
Victor
Victor
#1077
#1079
i have had some parts ordered in (im in usa i dont know if horizon ships to canada) via my lhs and the horizon route
unfortunately horizon parts searching on their website sucks the major wazuu
and should be re invented
#1080
sooo for my current wildfire... i need a new chassis and top deck to fit the new motor mount, throw out my 4 spare packs of arms, new bulk heads, new shock towers, new shocks to go with the bulk heads and towers, new servo mounts? do i atleast get to keep my current diffs and belts ???
