Losi XXX-S
#6932
Originally posted by Painy
hi guys,, just a quick question...
I was a at a recent race meeting,, my dillema was this: i was as fast down the straight....existing the cornerst..
But i would loose a car length during "mid Corner"..what would you do to carry more corner speed..
would you want to make the car looser..so as it didnt bog down as much or would you want more traction..
PS.. this is in Stock racing. on a high speed flowing track. with high traction,
#6933
Painy...
... lower roll center in front, or maybe arm spacing, will add a little to your mid corner steering...
#6935
but wont more steering cause the car to wash of speed?
car goes through the corner smoth and consistent.. just want it to go through faster.
i will try motre steering and see how it goes.
... maybe you should try letting off a little sooner, so that you can throtlle sooner, thus giving you better corner speed.
#6936
reducing weight
Does anyone know anypart numbers for Titanium turnbuckles, and any good ways to reduce weight from a regular xxx-s with graphite conversion kit.
#6937
Only way I know is to start milling the chassis in the right spots, that is to get rid of weight on a stock XX-S graphite chassis.
#6938
My LOSI XXX-S graphite, ceramic bearings & all matt francis hop ups (costed me around $1,000) is for sale!
It is on auction closing date 30th September 2003. Start to bid from as low as $100.00.
If interested send me a message. The bids will be online on a webpage (given at a later stage) ...
#6939
racedirector- if you dont have the aluminium cvd you should put it
will help !
will help !
#6940
question: on a flowing track, if your car has an off power understeer, would you add steering to the front or add rear rotation on the back? thanks...
#6942
a stupid question here : if a find my car a little loose is it better to add ( on rear) stability or traction or both ???
thanks
thanks
#6943
Originally posted by jkerr0043
I think I'd try adding steering and grip to the front. Is it going into the corner or mid corner? Going in I'd try moving the front arms back or laying the shocks down one hole.
#6944
highwayman: i would go with adding steering rather than free up the rear. if its off-power/mid-corner steering you need, i'd go with what jkerr said and go one hole in with the shocks on the front tower. if its turning in thats a problem, i'd move the front arms back a notch.
looks like we had the same problem during the last race. i just decided to be a bit concervative and not dial in more steering coz i was afraid the track conditions would change suddenly (as i know it does in the evening). looking back though, i should have put a tad more. i was a too slow in the corners. in the last main i had to work extra hard to keep dale behind me in the first half of the run and maintain the lead. but since he was so fast in the corners, its was inevitable he'd pass me - so he did. then next was ralph behind me and we were fighting for 2nd. he passed me but fortunately i was able to gain the place back. but it was really hard coz i lacked the speed in the corners. but it was great dicing with both of them. NEXT TIME!!! .... hehehe
#6945
ROBO:
actually, i had so much steering last saturday, that i had to de-tune the car last night, now, it seems it understeers too much... (last sat i had 0 deg caster, now i'm back to 4)
... BTW, i'm running diffs now, broke my 1 way last sat.
AUDI:
i was suppose to try it out last night (camber link positions), but it was getting pretty late, so we had to go home. i'll experiment with the camber link next practice.
.... B T W ... its mid corner to exit steering, entry is ok.
AUDI:
