TLR 8IGHT E 3.0 THREAD
#2311
I use a #20 and have never needed to go bigger than that.
I wouldn't recommend going bigger than a #20 unless you want to introduce slop a whole lot faster...
#2312
Some help needed,
I just got this buggy and was wondering about servos. Would the xp1015 or the spectrum 6090 work well with this buggy? I run spectrum so I want to avoid savox but these two were the top of my list. The only thing I see for spectrum is that you can run 7.4 vs the xp only runs 6. I will be running a 4s pack.
Thanks,
Thanks,
Just wanted to see if anyone could offer some advice.
#2313
For everyone that was having a terrible time getting the front arms to be free, I ended up testing an #18 drill bit --works perfect.
I tried the 10-32 tap like someone suggested for the droop screw, with some new arms before I tried to screw in the droop screw -- did nothing. Still wasn't free.
The #18 drill bit makes it nice and free, with only a VERY SLIGHT amount of play.
Hope this helps.
Hope this helps.
#2315
Just heard locally that the two don't mix well together and that you need an external cap to help regulate the power. I have an xp 1015 now just wondering if that would work? Im new to 8th scale, just a 2wd buggy guy.
#2316
I run a Savox 1256 in my 8E 2.0 and 3.0 buggies and a Savox 1267 in my 8T 2.0 truggy without a external cap and have zero issues.
#2317
http://www.amain.com/product_info.ph...ium-Gear-Servo
#2319
Hi,
Can you tell me what's about the Hudy reamer tool for the Losi arms ?
Did somebody try it ?
Is the 4mm one right, or we absolutely need ~4,2mm drill/tool/tap ?
Thanks,
Bye !
Thanks,
Bye !
#2320
I would steer away from the XP, they have a plastic gear that is common to break in 1/8th scale applications. I run Spectrum with a Futaba servo. Matched with a Tekin RX8 Gen2 set on the 7.4 voltage option. Works great.
FWIW most servo's have that dreaded "plastic" gear.
#2321
8ight e 3.0 rear shock Bodys getting scratched
Hello,
my problem is that my rear shock Bodys are getting scratched more and more.
I have only driven this car 5 Trackdays long on an astroturf track, so Stones couldnt have scratched them up.
Even the thread is damaged a bit
Does someone have the Same Problems?
Sorry for my Language, im from Germany
#2322
Amorpher PIc from the right shock body
#2324
Can i Protect the shock Bodys somehow?
#2325
Another question regarding servos. I ran the xp1015 and it feels good but I think it needs a little more. What is a good amount of torque and speed that I should be looking for? Do you need more torque over speed? I was also looking at the spectrum 6090 or the futuba 9352 and was wondering which would be better for the buggy?
